I had this motor built for my Beetle project, but as I have a new toy I dont have a need for it anymore.
Fully rebuilt 1776 T3 (Converted to T1) motor. Eng No RR16204. Just been rebuilt by VW trained mechanic.
Has,
- New 1776 P & C's
- Re-ground standard crank (20thou)
- Re-built Twin Port Heads (New valves)
All assembled to long motor stage.
Also fitted with a 200mm x 6volt Flywheel so it will drop straight onto a 6volt gear box , but have the added benefit of the larger 200mm clutch.
Comes with late 1600 dog house cooler style tin and cooler.
And all the upper tin.
I will also be including the following accessories
- Set of Weber 34 ICT carbs with T/P manifolds and linkages.
- New Scat Alloy Degree Pulley
- New set of Scat clip on Stainless Steel Valve covers.
To complete you would need, exhaust system, generator and stand, distrubutor and associated ignition parts. Clutch ect.
Price - $2,200.00.
Located in Melb. Can deliver anwhere in Melb metro area.
Call Dean 0412 500 588 or U2U
Grey 57 ·
waltermitty ·
bargin!
11CAB ·
They look like single port manifolds to me......
Grey 57 ·
Good point Graeme. The ones in the 2nd pic dont come with this motor. I promised them to krusinkombi. Look close at the motor pic and the t/p manifolds are there. Using them to seal the motor up.
DubCrazy ·
mmm wouldn't that go just right in the back of the baja i am doing.... wonder what i can sell ???
steff.........................
11CAB ·
So Dean, about that ride in the ghia.......:thumb
Grey 57 ·
done deal Graeme. :thumb
11CAB ·
Only about 18 months away......but I'm looking forward to it.....:thumb
Grey 57 ·
bump 🙂
Grey 57 ·
no one wants an inexpensive motor then? :thumb
DubCrazy ·
i want just the bank doesn't unless you accept easy pament terms, 10 buck a week till payed off 😉
Grey 57 ·
One more bumo then into the Trading Post.
Sorry DubCrazy, need the cash out it for my other project. 😎
