Hey guys. I'm from Adelaide and i just bought myself a slightly damaged 1971 1300 Beetle. It is very clean on the inside and most of the outside except for a 2 minor dents. I also bought a convertable 1600 as the 1300's engine is f*cked... The 1600 is nowhere near as clean as the 1300 so i'm gonna use the engine from the 1600 in the 1300 and stick with the rest of the 1300...
Now the mags are literally just the rim... the one you can put a hubcap over... i'm most likely going to get the beetle painted black and i was looking at some new 17" rims... This is where the problem begins. Standard rims are 15" but i know nothing about the nut configurations and the offset. I don't even know how to figure it out. Now this is what i read off of the standard tyres: "165 R15 86 S Radial Tubeless OR 34"... I have no fricking idea what this means... i just need to know all the information i need to tell a tyre company so that they know what rims to give me...
Cheers for any help!
vwtyp2 路
being a '71, it's probably a 4 bolt rim.
if so, I think it's a 4x112pcd. that's the bolt pattern of your rim.
you'll need to know the offset of the rim too.
this is usually stamped on the rim somewhere. you;ll see something like 4.5jj 14.
4.5 is the width of the rim, jj is the offset ( I don't know how this translates on mm) and 14 is the diameter of the rim.
best bet is to take a rim to the tyre place, or better still, the whole car, and try a vew rim styles on your car.
it does help though if you know your bolt pattern and offset when you're choosing rims, so you know what's gonna fit for starters.
BTW, welcome to the forum. 馃槈
where in Adelaide are you?
Trevally 路
Cheers. I look at the rim when the heat dies down... I'm in woodville area... Only 16 but got the car for something to do in the holidays and now i can't stop planning things. My dad and i were supposed to go pick up the 1600 today but we forgot...
anyway cheers for that... i'll get back to you when i look at the tyre next.
vwtyp2 路
sorry, just re-read your post.
you're using the 1300 right? with the 1600 engine.
in that case, you have "wide 5" bolt pattern. (5x205 pcd)
you're limited to about 6 styles of rim, unless you use adaptor plates, or get your drums drilled to a new bolt pattern, or change your brakes.
but don't worry, some of the 5x205 pcd rims look sweet.
nearly all of them are 15"s though.
vwtyp2 路
no probs, I'm at Klemzig, about 20 mins from you.
while it's hot outside, have a play with this, and get some paint/wheel/ride height ideas.
good way to waste an afternoon.
4 stud is 4x130 pcd.
j -i think refers to the wheel being a safety rim which they're all required to be.
ET is the usual designation for offset, but i don't know what value is best.
Trevally 路
Nah i'm pretty sure they are 4 nut... i just got out there (and straight back in after 30 seconds!) and looked at the wheels. the spare is 4 nut but i can't see the others because of that chrome cap... how do i get that piece of crap off? I looked at the rubber on all of the tyres but its hard while your standing up, and i didn't notice anything apart from the fact that the rubber is a different brand on every wheel! Kumho on this one and some japanese brand on the next...
Played with that site and i like it馃槑. Only rims i liked were the porsche ones at the end... not into that other chromed stuff... I really want something like these rims: LINK
bus914 路
these have the 4 stud pattern
Trevally 路
Those rims馃槈. When you say "these" are you refering to the car or the wheels?
bus914 路
both.
if i remember the old magazine article correctly the wheels are simmons brand and were made in the correct pcd. the owner is in Australia someone here may know him.
hubcaps have 2 small holes on the outer edge. the hubcap removal tool looks like this:
Trevally 路
Nice... About that tool... where the hell do i find that? thats ok i'll go look for it now...
Trevally 路
Found it... bloody thing was too small so i used a bar of metal as a handle and pulled it off... it was pretty damn rusted under there... its 4 nut.
Now when you refer to numbers like
4x130 pcd
Is that the gap (in mm) between each nut? i assume it is but if it is then is that (in the picture) following path A or B?
Che Castro 路
Hey. the pattern of the holes is called the PCD (pitch circle diameter)
here is a good article which will show you everything you need to know
17 ins would be cool, but if you drop it you will probably run into another problem or two. Unless you get a narrowed beam in there.
Most of the "New Rim" choices out there are for new cars, what you will have to do is use adaptor plates like previously posted, this again can throw your offset out further and cause your tires to rub your fenders everytime you turn a corner or hit a bump. If you don't drop it with 17 s you would look like you where ready to Baja. Your car though do what makes you happy though馃槈 My first car at yoir age was a 72 super beetle. I loved dreamin about all the stuff to do to it. Have fun and good luck!
Trevally 路
Cheers... I just read that whole article and that guy is a legend but makes it seem like a whole lot of work...
vwtyp2 - where do you get spares etc for your beetle in SA?
Che Castro 路
You should also take note of legalities. in NSW spacers are illegal unless fitted from factory (none of the aircooled VW's were as far as I know). Also adaptors that have two stud patterns are illegal as well.
There are rules regarding wheel width and diamter too. Must be within +/- 15mm overall rolling diameter (this is for the tyre). Also wheel width is regulated - look at this link http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi09_rev4.pdf Obviously this is only for NSW.
A cheap and legal solution would be to get new blank discs and drums and have them drilled for 4x100 PCD - same as a lot of modern small cars - this gives you a lot of choice of rims.
Trevally 路
Where do i get new blank discs?
I'm pretty sure S.A. doesn't have as strict rules as NSW... YET...
Trevally 路
Ok guys, We got the 1600 delivered (towed to our house...) today. Like i said the thing is in shocking condition inside and out:puke... only good thing is the engine. SOUNDS TOUGH:thumb:thumb:thumb!
The wheels are 4 nut (???)... Is that what they are supposed to be? and they are about 130PCD... just did a rough measurement with a ruler. Also they are 195 75 R14... Does that make them bigger or smaller than the 1300s wheels?
Anyone know if this is a genuine 1600 and or what model it is etc?
In other words anyone know anything about this model? pros cons any warnings etc?
[Edited on 11-1-2005 by Trevally]
vwtyp2 路
closest to you would be Volksfactory at Braeside Ave, Holden Hill.
speak to Paul, and tell him Daniel from the bike shop sent you.
or for servicing, Bob at VolksCare at Tania ave. Windsor Gardens.
you can fit big rims, if you find the right bolt pattert, the right offset, and the right width.
check out the 17"s on my Bay.
they're 17x8" ROH adrenaline with 225/45 rubber.
vwtyp2 路
before that, I had MWS BRM replicas in 5x112 pcd.
thet're a 15x5.5"
Trevally 路
That looks crazy! I like it. Did you have to get your thingos (i keep forgetting what they're called) drilled for a different PCD or did they just fit normally? Can the guys from Volksfactory supply me with predrilled drums, or whatever they are called, with the right PCD i need (4x100) or can they drill mine as they are?
Also there is a place right next to Castle Plaza edwardstown called Volks Auto and they were going to fix the original 1300 engine we had before we decide to scrap that idea and just buy a 1600 with a working engine...
cheers for that.
BiX 路
the other option, is to get some custom made. eg by simmons, they will drill a wheel to suit your pattern. but it depends on how much you want to spend.
vwtyp2 路
the wheels I have now came off a Mercedes.
they're the same pcd as Kombi, so they bolt straight on.
some BMW's are the same too.
you'll find that a few cars share wheel sizes.
if you go the 4x100 pattern, it's a common size.
used by mk 1, 2, & 3 golf; heaps of jap cars, pulsars, lancers, etc.
this will give you heaps of wheel options.
look at 2nd hand ones too, you'll find heaps of ricers trade in their 17"s to get 19"s, so you can get cheap packages.
I think it's illegal to have your drums double drilled. I may be wrong.
best to get new blank drums, and get them drilled, and do your brake shoes while you're at it. then you've got new brakes.
you could also try Dean at Intervolks on Main North rd. for your drums.
price of reconditioning/rebuilding an eng. is pretty pricey.
volks auto is where we get our mk 4 golf serviced.
I'm good mates with Andrew who works there.
probably easier and cheaper to pick up a running 1600 twin port from Volks Factory or VolksCare.
:beer
Trevally 路
Well BiX, I'm looking at spending as little as possible but staying legal. Also want a different PCD not just specialised rims otherwise i'd have to go to them everytime i want new rims...
Vwtyp2, How much would the new blank drums cost me for a set of 4? Why would i need to do the break shoes?
If its not illegal to double drill the drums then i could do it at home as we have a stainless steel company that we kind of operate in our backyard. We have proper drill presses and HEAPS of other heavy duty tools. The guy that works for us is a legend at welding stainless and mild steel so he should be able to weld something over the originally drilled holes and grind them down to look like nothing was ever changed馃槈...
How does that sound?
vwtyp2 路
you could re drill. that's what most pleces do anyway. and if you have the facilities, go for it.
you may not need the brake shoes, just a good time to do it, while everythings apart.
I'd say just re-drill your old drums, it's gonna cost you next to bugger all, and you can do it in whatever bolt pattern you like.
Trevally 路
Yeah if anything i would get them redrilled but how do i get the correct PCD if you draw the circle through the middle of where the nut sits? That makes it slightly harder... although i think i know how it could be done... By drawing 2 lines diagonally accross to each nut (like in the picture) and redrilling each nut exactly 15mm further down on that line. 15mm from one side and 15mm from the other makes the circles diameter 30mm shorter leaving the PCD at 4x100... does that sound right?
vwtyp2 路
that sounds about right, one way of doing it.
or put the drum in a lathe, and centre it, then mark your 100mm diameter in there, and use that as a centre.
If you call around the vw places, one of them may have a jig to re drill hubs.
try Car-Tek (formerly vee dub centre) on south road at edwardstown.
Trevally 路
Cheers for that. Car Tek is right next to my dads work so shouldn't be hard to get them to do it... Do you know how much they'll charge?
Oh by the way i read that thread in the drags section about your first attempt. Looks nuts when launching and goodluck next time!
vwtyp2 路
not sure, give them a call.
speak to Michael or Shane.
thanks, I can't wait till next time.
malcolm 路
divide 4 into 360 and that will give you the angle of each hole but get a engineering shop to do it.overall diameter is worked out by width multiplied by . profile times 2 + diameter of wheel = overall diameter convert wheel dia into mm. ie,165/80/15=645 155/80/15=629 so a 205/45/17=616.3 I,m using a 205/45/17=616.3 on the front an a 225/40/18=637.2 on the back both a within the 15mm+/- of the orignal overall diameter. go with of an ET 35-50 V-force can drill blank disc or drums in any pcd.
Trevally 路
Ok... that all looks a bit confusing to me (hence the title of the thread馃槈). So like you said i'll get an engineer to do it. I'm in Adelaide so i have no idea what V-force is???
malcolm 路
v-force is a company in sydney they can supply the disc & drums drilled in any PCD you want. pcd,s 4x100 is common in smaller cars or 5x114.3 in larger cars any 3peice wheel will cost from $700 up each simmons and roh can make a 17x6 or 17x6.5 with any ET so you wont have any clearencing issues. Enkie make high quaulity 1peice alloy wheels in a wide size range and pcd,s, et,s are good to as well as the weight eg 17x7 weighs 6.5 kg.
Trevally 路
Are you saying $700 for each rim custom made or for redrilling standard/new drums? I dont want to go sending off my drums to sydney to get them drilled when i could get it done here... i don't see the point.
malcolm 路
$700+ per 3peice rim not pcd,s redrilled
Trevally 路
Yeah i didn't think it would cost so much for redrilling drums... Like i said before i think getting rims custom made is pointless because then i can't change them later i have to get them custom made again. Gonna cost me an arm and a leg for that... i might as well spend say... 100 bucks to get them redrilled? We know HEAPS of people that would probably do them for next to nothing BUT probably not as accurate as if an engineer was to mark it out and drill them himself...
