Accelerator pedal parts
https://forums.aussieveedubbers.com/threads/33995/accelerator-pedal-parts
UncleRudi ·
My accelerator pedal is missing some parts, it jams forward at times and there doesn't seem to be an even movement back and forth. I'm guessing I need to fix the parts between the pedal and the base, any suggestions where I can find these parts?:o
gazza ·
uncle rudi, how are you mate? what sort of VW do you have and what year???? i'm wrecking my beetle and may have the parts you need....
i'm wrecking a 70'model 1500 beetle
cheers gazza
UncleRudi ·
Howdy. Mines a 65 bug, I don't know much about what would be suitable. I'm just learning about VW's, talk about a steep learning curve!!!
karmen ·
check your carbie springs are ok and effective
then get under the car near gbx and see if the cable is twisted around anything wile someone operates the pedal
also clear all sand and gravel from under pedal
check and grease up the hinge and keep it clean
the pedal also has a primitive return spring which should operate but may be broken
