Trawling around my PC I found a couple of photos of my 73 1303 while I was building it. Reminded me exactly how much rust the damn thing had.
Doesnt look so bad does it ?
[ Edited on 29-6-2005 by Doug Sweetman ]
Doug Sweetman ·
Right rear needed a little bit of work.....
Matching bolt holes and panel profiles provided a challenge.
Doug Sweetman ·
And on the inside as well.
Damn that VW foam they put in there !
[Edited on 11-1-2005 by Doug Sweetman]
Doug Sweetman ·
Heads are bog standard 040's
Carbs were going to be 40 IDF's but I could never find someone to tune them, so they are still in the shed.
Doug Sweetman ·
So it got registered with a single 40 DCNF.
Which Sucked big time.
Doug Sweetman ·
And now it gets about OK with Kadrons.
Though now I have K&N's on it and a homemade breather box too.
Desert Moose ·
any pic's of your K&N setup
Doug Sweetman ·
Not on my work computer - I might have one at home, otherwise I can charge the digicam up and take some. Anything you wanted to see in particular ?
They are just K&N inserts to the std kadron filter top and bottom plates - they are a bit taller though, so the central stud needs to be extended to cope.
Desert Moose ·
Doug Sweetman wrote:Not on my work computer - I might have one at home, otherwise I can charge the digicam up and take some. Anything you wanted to see in particular ?
I still haven't done anything with mine, and I'm looking for ideas.
Doug Sweetman ·
This is the only photo that I have with the K&N's on - they look heaps better.
Kurt and Troy and Vee Dub Repairs and Spares did the work, so they should be able to give you the part numebr for the filter I guess.
GL1972 ·
Doug,
The rust in mine was almost identical! I share your pain. Good job.
Patience is a virtue but rust destroys the souls of the virtuous!
Brendan
Doug Sweetman ·
Thanks Brendan - it was a learning process for me. I learnt that there is no such thing as 'surface rust' in a 1970's beetle !
Doug Sweetman ·
Some more up to date photos, and some photos from my win in the WA VW Club motorkhana last year.
[ Edited on 28-6-2005 by Doug Sweetman ]
Great stuff Doug!!
Robo ·
Another Beetle saved!
Who owns the shed she's in in the first shot?
Rob...
Doug Sweetman ·
Thats one of my old man's sheds. Its a good size (15 x 9m) for a 700sqm suburban block......
Thanks Barry, I'd had those photos for a while and never found a quiet hour to put them up - thought there might be a few on here that would enjoy them as much as I enjoyed the day !
zac_smits ·
that's not a khana...
that's just you in a paddock :P:P
(but still looks cool!)
Doug Sweetman ·
Actually the photos are my celebratory donuts after the khana 🙂 I have a really cool trophy at home (which I guess I have to give back one day) with a vw conrod (bent at 45°), piston and half a valve embedded int he top of the piston, all mounted on jarrah burl, real nice.
sshhhhh dont tell anyone there was only four people competing in the khana though........
