1641 Carb size?
https://forums.aussieveedubbers.com/threads/34013/1641-carb-size
Boozer ·
Ok. now that i've confirmed that my old engine was a 1641 i need to find out a few things.
1. compression ratio.
2. what carbs would be suitable for it? preferably single not twin carbs and where to find/get them would be good.
3. and any other usefull info you think i might need. :thumb
11CAB ·
A pict 34 would be fine for it
I had a 1776 with a 40 DCNF on it then changed it back to a pict34 and it went pretty much as well as the weber up to about 4500rpm and had a choke as well....
64vwmark ·
My 1641 has a 40 DCNF Weber as well. It works ok and is easy to tune. I'm told that twins are much better though as the intake manifold is too long with the single carb. I'll get to try out some twins soon, a family friend is giving me some!!
Oasis ·
twins are no good for off road as the linkages are a bit too fragile so I'm told, but of course good for going FAST:bounce
GL1972 ·
How about a progressive Weber DCD/Holley 5200 32/34 or 32/36 (not sure if I got the designations correct). Once tuned they give good performance and are economical.
Brendan
Stay with the standard carb.......................the motor probably has a standard cam so why pour more fuel into it.
If you are running Baja extractors then rejet the main to a 135 or even a 140 jet.
Quoll ·
2100 bugspray with a non-plenum manifold
:thumb
MUD BASHING ANYONE ?? ·
If your just doing a top ender make sure that the bottem end is still good by getting two flat bladed screew drivers and putting one on ether side of the flywheel and moving it from side to side and up and down and if there is move ment is not so great if theres alot put it in the bin and find a type 4. and the carby stick with the stocker yor motor will not have enough anything to need a webber it will only go worse and use more fuel
Doug Sweetman ·
If you put a properly jetted and tuned 32/36 DGAV progressive weber on any 1600 and larger engine with a better exhaust (its a baja, it must have extractors of one form or another) you will end up with great driveability and a nice performance improvement. Get the mechanical secondary version - you can drive around on one barrel of the carb to save fuel, and give it a bootful when you need it.
Or you could stick with the stock 34 pict, it will work fine, I just think (from experience) that the progressive 2 bbl webers are great value for money and can waken up a 1600 a bit more.
barls ·
they go alright with a prog webber i had one on my big bore still have the carb too if your interested. the only problem is the manifold was used with a different carb. but if you want it let me know
Doug Sweetman ·
Oh, and regards the compression ratio, dont go above about 8.5 : 1 without starting to look at external coolers etc.
