Brake Fluid Hose - reservior to master cylinder
https://forums.aussieveedubbers.com/threads/34059/brake-fluid-hose-reservior-to-master-cylinder
56astro ·
The black rubber hose I have been using is weeping brake fluid along its entire length.
What type of hose does everyone use??
PurpleT3 ·
Brake hose, I think there is a specific blue hose used for this purpose.
Jeza ·
Yep there is specific blue brake hose for this purpose, and its really expensive!! But you should not need much lenght as it only fits between the hard line pieces.
I also tried fuel line as that is what I was recommended, but it wept like crazy and mucked up all the paint.
56astro ·
thanks
better get some before my paints gets damaged then
All the VW Shops sell it....
Its special brake hose.....
and as someone said its expensive but its the only one to use... once its pushed onto the pipe....
It cannot be pulled off.... and lasts until its cut off ...
usually about 30+ years....
I really can't believe that You would try something else....
All rubbers used in or with brake fluid must be a special rubber.... O rings etc included.... otherwise they will swell...
56astro ·
68AutoBug wrote:I really can't believe that You would try something else....
<in jest>
I'm sorry Lee,
I promise not to do it again,
I promise to try harder next time!
:thumb
the late models ( twin master cylinder ) use the Blue hose with about an 8mm dia
The pre 67 single master cylinder hose is different and green and small ID of course.
56astro ·
Thanks Dave
Does V V D S sell this?
BTW
What's the go with Melbourne Bitter? I thought it was "Crownies or nuthin!"
Yep VVDS have it in stock
Melbourne Bitter just 4 a change, went off the Crownies
56astro ·
Was speaking with a brake mechanic the other day and was explaining the weeping I was experiencing, and he said that it could have been "condensation" on the outside of the rubber hose. This, he explained, occurs because brake fluid is HYDROSCOPIC and attracts water.
Not sure if that is the case or not, but I'm replacing the hoses now anyway.
