as much as i dont want to let these go but im forced so here gos
2 full sets full set of vdo guages these have the same lines in the faces as early bug and bus
1st set
oil /amp/ fuel and the super rare oil temp
they are in graet condition for there age i have not tested them but im shore there would be now probs i was going to have the temp and oil converted to full electic any way after a lot of searching
on samba ebay and other uk site ive come up with a price of $330 cash for the set and now theres now senders
if you want these ring me first in best dressed
0412122467
97042474
travis vic
:cry
[Edited on 14-1-2005 by low55]
low55 ·
low55 ·
heres more these ones are not as good but still nice condition the oil temp needs glass and chrome same as
deal as above but $280 cash
travis 0412122467
vic
low55 ·
heres 1 oil gauge as is $35 cash
travis 0412122467 vic
ruckus ·
Hey travis I've got the same set. Where can I get the senders from and how hard to convert the oil ones to elec?
low55 ·
i have done it my self by use ing a later style gauge and just using the face body glass and trim so u have to pull it apart and build one from two make sure the needle has the same amout of travel tho it takes a bit to nuting out but werth it in the end and you can still by needles and glass and trims from vdo so they can be brand new again
travis
Che Castro ·
sorry but do you mean you have to use the later style face to convert it to electric? i was under the impression that electric gauges couldnt use more than about 120 deg sweep and mechanical could almost go 360 deg
low55 ·
yes that is sort of write i found a cheap eletric one at berwick swop meet it had a 320 degree travel so i used that sorry i should have stated that
travis
