It definitely should have one to prevent hot air from the exhaust recirculating into the engine bay. I have no idea what it is called though, sorry.
Woozy ·
I think it's called a skirt ?
may be mistaken tho
mnsKmobi ·
These are Type 1 motors. Your engine bay will look different if you have a Type IV motor as it takes up more of the engine bay.
Listy ·
not sure if it's type 4..
it's a 1600... 1974
I have got the surround that is in two parts that goes around the motor, but not this skirt.
Ian
11CAB ·
Are you talking about the rear valance?
You'll need that to seal the engine bay and also for the engine lid to close onto.
amazer ·
yours should be different to this. a 74 from australia has different tinware to that, and the rear piece doesnt bolt in. Looking at those pics its an earlier model. (different bumpers) maybe 68-72. So long as when you look inside the engine bay you cant see through to the ground or the exhaust then you are OK. I am thinking your engine bay should have the raised section on the left like in this pic. Your engine will be different but that was accomodated by using different tin.
amazer ·
hmm so that didnt work.
Listy ·
yes amazer...that is what mine looks like, and i can't see the floor. what a relief! 🙂
