I cant find anyone here (NZ) who has done this, or can do this without it being cheaper to go and buy a new case.
Any suggestions from your side of the ditch appreciated.
... might just be quicker and easier to get a new case, methinks
koolkarmakombi ·
new case......
eight resets to machine out the hole, fit inserts them machine to size not be cheap.
If you have to re sleeve the bores ..... then i think you will find lots more problems with the crankcase.
Yes it is cheaper to purchase a new case. I can not recall anyone doing this process
I paid $80 for crank & case a few weeks ago. It's getting built into a hottie right now. Sleeving would be hours setting up, machining etc - therefore $$$$
AdrianH ·
Thanks.
The case is only 1000 miles old, it is std apart from this problem. I may end up sending it to the US, cost dependant, or it may become an expensive coffee table leg !!!
Keith Haeusler ·
Adrian,
I just had the same problem, u2u me. Keith.
