help with transmition
https://forums.aussieveedubbers.com/threads/34758/help-with-transmition
billbobmc ·
my 1973 type 2 2ltr. auto has been givin me trouble. the trans oil was originaly burning up white...then i got a new pressure valve, topped up the atf. drove for a hour then, slipped out of gear, was registering no gear at all and was registering no atf, with no visible leaks and no burning???
after a few times of filling it with atf, it ran for a bit, then slipped.....by the time i got home, i had to reverse up a huge hill then, after i turned around, all the gears went.
now.......i filled up atf, registers, but no front gears, just reverse.
help.............................................................................
i live so far out and must try to fix myself.....
any thing is good.
thanx
billbob
seagull ·
Mate your in more shit than the first setlers !
I think you will find the converter is not full yet , try running then stop it >some more oil , best of luck , seagull
seagull ·
If the bands are cooked it may be stuffed :jesus
billbobmc ·
please tell me the names of the bands in the book of kombi.
i need a place to begin.....
send me your kknowledge.
peace
love
brown rice
seagull ·
You would need to strip the auto down , its a big job and BIGGER if you dont know what your doing .
I would say you have cooked it and it needs a total rebuild .
billbobmc ·
would you think trusting a second hand auto trans from a 73 type 2 that has not moved in 10 years (in a wrek) but apparently it worked when it was parked.
should i compleetly overhaul mine or just put the (new) one in or...............should i overhaul the (new) one b4 it goes in to the kkkkkkkkkkkombi?????
peace love......
ps. gonna have to pay to get it done.................
wachathinkitsgonnacost?
thanx
bill:kiss
seagull ·
To recon one of those boxes arround $1000.00 > $1500.00 .
get the second had box change the oil > if water has not got into the inside it will be ok .
seagull ·
Thinking here ? if you remove the pan >then the strainer / filter is the metal in there ?
The oil smell like its burnt ?
