Just a quickie.
https://forums.aussieveedubbers.com/threads/34763/just-a-quickie
E 路
With tyre sizes, does it matter what size I shove on the beetle? I know its a stupid question, but Im just curious if Id slowly destroy my axles or torsion bars or whatever by having a 17" wheel as opposed to a 14".
Gibbo 路
do a quick search, there have been several discussions about tyre sizes recently.
馃檪
Chewy 路
Whats more crucial is the mounting off-set of the wheels.
Too inboard an offset will cause premature wear to steering and suspensions components.
GL1972 路
RTA stipulates you can't change your wheel track by more than 25mm. If you can fit them in and you keep your overall diameter less than +/- 15mm and you keep the track as above you should be ok. I got 17 x 7 inch rims with 215/45 tyres...worked out to +4mm track( ET 35 backspacing), -10mm diameter.
Brendan:jesus
