I have just had a bit of an overhaul of my 74 Kombie, one of the things while driving from the garage home I noticed is when indicating right the indicator freezes (stops) , left is fine (constant as usual) I have since found out that it does it when I have my foot on the break any ideas what the hell this is and how to fix this problem.
Any ideas guys?
Stevie Boy!!!
karmen ·
check poor earth
and also corroded connections
incl those in the fuse box and the lights and the juction boxes
remmeber these things are getting olde !!
shamer11 ·
Where do I find all that then?
SB!!!
shamer11 ·
Thanks BTW
All help most welcome
SB!!!
Bungawatta ·
I'd be happy to give you a hand, not that I'm confident to fix the problem but I can help. 🙂
Where about are you in Brisbane? Or can you come around near UQ?
ratty 63 ·
If its only happening when the brakes are on, then it is most likely that it will be a bad earth on the taillight housing on the side of the problem. Remove all the screws from the earth wire (brown wire in earlier cars - not sure of color in your car though, but will still be under a screw that is attached to the body close-by) and clean the connections before replacing the screw.
