Aussieveedubbers 路 Tech Talk
steering collum on super 71
https://forums.aussieveedubbers.com/threads/35095/steering-collum-on-super-71
akean1 路
trying to put steering back together on my 71, looks like the shaft should go futher towards the steering wheel end, as there is a gap (highlighted in picture) near the coupler. is this as far as they go? or if it should be furthe in, what could be stopping it?
:duh
akean1 路
someone help? i want to be able to tun the wheels again馃檨
Bizarre 路
My cars have all been 1303's - but sure they are the same
There is normally a big rubber donut thing that suppots the shaft that sits there.
Do you have this or has it been pushed up the tube like mine was???
I will try and do a search and see if i have some pictures
akean1 路
there is something in the end of the tube, but looks like it should be there, i dont remember a ruber donut when i was removing it. is this part important?
Bizarre 路
It supports the shaft
It has been a while since i have pulled mine to pieces
I seem to remember a roller bearing that is in the welded tube and the rubber bit at the end
I will take a pic of a spare set up I have at home.
Remembering it is for a 1303 - but i dont think that matters.
Will also look in some manuals i have
Bizarre 路
here we go
Thankks Dorinda and Mark (SBO)
Piece 11 is what i am talking about
Bizarre 路
too big
try again
Bizarre 路
and
akean1 路
thanks for that馃檪
Bizarre 路
this is the bit i am talking about - this one you can see the marks where it was just shoved up the tube. If you can t see it it cant be in the wrong spot !!!
I have had 3 1303's and not one of them had the bit in the right place.
One had the wrong coupler
All 3 need to be set up right.
Once you have done this and adjusted the box and made sure the coupler has no play you will be amazed how wonderful a super steers.
Then go and drive a 75 with R&P and be amazed again
Save for a set of struts as well
WELL worth the $$$
u2u me if you are having trouble with that piece
Bizarre 路
馃槈
toplessbug 路
purchase urethane and put it right thru your front end you wont believe how much difference it makes for such a small amount of bucks--youll be seriously amazed
