I have just finally put the baja's engine back together to great happines and joy 馃檪 :bounce:bounce:bounce
I then had the carbie's retuned and in the process have found a bery confusing problem.
On the compression stroke (it appears to be on all 4 cyninders) there is a whooshing sound (kinda like ffffffffffft)
as though air/fuel mixture is leaking somewhere
I have been told that this is normally to od with the mating of the cylinders to the heads tho this problem is normally accompanied by a popping sound on accelleration. There is no popping sound.
If anyone has any ideas or novel solutions the would be appreciated otherwise i guess ill have to pull the engine again 馃檨馃檨馃檨馃檨馃檨馃檨馃檨馃檨馃檨馃檨馃檨馃檨
:puke:repuke:puke
Woozy 路
