CHASSIS NUMBER ON THE TRIPLE CAB: 603576. What did it start life as????
https://forums.aussieveedubbers.com/threads/35204/chassis-number-on-the-triple-cab-603576-what-did-it-start-life-as
preacherman ·
Hey I'm trying to find the chassis number on the Triple cab and don't know where to look. The plate behind the drivers seat is missing but I know it is stamped somewhare and just cant remember where.
Anyone help? thanks.
[Edited on 24-2-2005 by preacherman]
VolksFolks ·
to the left of the motor, at the back
Andy
preacherman ·
Thanks Andy The chassis number is VWK7157. Can anyone tell me the date and type of bus it was from this chassis no please.
Stealth ·
you will need a chassis number that is only numbers (ie no letters) the chassis number is stamped under the ID plate located on the right side of the engine bay when looking into the engine. OR if it's a late model it might be on the drivers side, behind the drivers seat, mounted to the bulk head panel.
preacherman ·
The Triple was a 1959 15 window originally. I will try those places you mentioned tomorrow and post number. Thanks for the info
Stealth ·
number stamped into body (under this plate) should be the same as id plate chassis number.
This photo is from a 58.
[Edited on 23-2-2005 by Aussie BLKBUG]
preacherman ·
Thanks for the great pic. I will clean off grease/oil in that area and the like tomorrow and confirm chassis number.
twoguns ·
preacherman wrote:The Triple was a 1959 15 window originally. I will try those places you mentioned tomorrow and post number. Thanks for the info
you sure it was a 15? maybe a 13 as the 15 would mean rear quarter windows... but they are not there now. he didnt hack two buses for the triute, did he? :duh
preacherman ·
I had a good look at her today and can clearly see the panels off another bus welded in both the corners. I will have a closer look tomorrow but I think it was a 15!! shame eh as they are as rare as 23 windows now.
nicko ·
Does any one know what the numbers stamped on the left side of the engine bay are for?
~air fooled~ ·
for a good time call....:P:P:P:P she might be a bit past her prime now hahaha
preacherman ·
The chassis number on the right hand side is 603576
Can anyone tell me what the Triple Cab started life as please?
57kombi ·
From that number all I can tell is it was made between March and May 1960.
Dave
