T25 nee T3 EFI Petrol Tank wanted
https://forums.aussieveedubbers.com/threads/35213/t25-nee-t3-efi-petrol-tank-wanted
humpty ·
The title says it all really....
T25 nee T3 EFI Petrol Tank wanted...Still!
Can anyone help?
I know DB has one, but it is damaged...Anyone help me out?
I'm in WA, but that is not really an issue...
Common guys, help me out here!
countrybuggy ·
can i ask what is wrong with yours if it is rusty they all seem to be...
humpty ·
Not rusty...Wrong size outlet for a my monster motor conversion!!!
I need the later large (10mm?) outlet.
If I can't find one, I'll look at modding what I have....Have to decide this weekend!!
Do you know anyone who can mod fuel tanks???
Brad ·
moding the fuel tank on a T25 isn't real hard. I am about to fit an EJ 22 into my EJ25 and there isn't a lot to it. Most radiator places will do it for you if you like.
humpty ·
Thanks for the tip Brad...I'll look into that! I believe the feed and return lines run to the centre of the tank via plastic pipes and in the centre well a mesh is found. I have also heard that this mesh has been the cause of plenty of fuel problems for the T25.
So removing the mesh and replacing the plastic lines will be the next job if i have to follow this path....Also got to weigh up the cost difference between replacement or repair....
Will it never end!!!
