anyone had this problem? (ceased engine lid)
https://forums.aussieveedubbers.com/threads/35346/anyone-had-this-problem-ceased-engine-lid
Jonno777 路
So I bought a kombi (61) and didn't ask to see the engine. Ha. I can't open the lid, it's ceased shut... any suggestions that might help me not break something?
penguin 路
馃檨 sorry not I, but have a bump on me
karmen 路
if you can trace the prob to be the hinges
then soak them in oil , wd40, crc, anything.
rusty streaks will develop down the paintwork
then slowly work the hinges loose.
failing that post me a pic and perhaps (i aint seen the model)
...the pins can be knocked out like on a door of aroom.
OR is it the lock ?
Jonno777 路
Thanks Karmen,
I'll try a flood of wd40, but I think it's the snib. Like there's the hole you put the little gadget in to turn the snib..
I don't have the gadget but the guy said a screwdriver should work. (?)
57kombi 路
The hole accepts what is called a chuch key
This is square and about 1 cm wide, a screw driver should work.
Look inside the hole so you know what size screwdriver to use. It turns to the right, clockwise
Dave
karmen 路
if it don't work sell it to me
needs to be a screwdriver close to 1 cm wide.
The bigger the handle the better
spray in the hole too
post a pic of the beast 2 pls
