sealed headlights kits.
https://forums.aussieveedubbers.com/threads/35418/sealed-headlights-kits
twoguns ·
i am wanting to use sealed headlights in the dcab. does anybody no where i can get them? i have seen and heard but dont remember where?
thanks
barls ·
like the early golf h4s wes my old man has them if that helps
twoguns ·
i am looking for the whole unit. i have been trying to play with the bits off the ute, but a lot of it is no good. so i need the frame case as well as the sealed unit, and the adjsuting screws and trim bits.
koolkarmakombi ·
try import advantage
twoguns ·
who? do you have a contact or link?
BiX ·
Umm i run mk1 golf units in my bug. they come with adjusting screws etc, they bolt/screw into the 3 tabs that you get in side the hedlight bucket. just need to get a trim ring to go over the top, and also they allow you to use a std h4 bulb, so if you loose a headlight you can get one anywhere.
If you have teh steel tabs ( or can fab some up pretty easy) you should be fine.
