Important Fixing pulled headstud quickly
https://forums.aussieveedubbers.com/threads/35706/important-fixing-pulled-headstud-quickly
Adam_C ·
ok heres the GO
i gota do a thing for a wedding and well my car was making a chuffing noise,..... the bastard was running but barely, but then as i started it today it ran like a complete bastard .... like it was on 2 cyl.... i think ife pulled a headstud out from the pass side..... how can i fix it quick or do i have to pull the engine and fuck around with a headstud that will cut into the case
HELP!
helterskelter400 ·
i has similar prob and had to stuff around with the tapping/cutting studs. bit easier with a buggy tho...
but be warned. i am no expert.
bugDbug ·
Its a helicoil job, isn't it?
Adam_C ·
well i tightened it and its better.... and i the sparkies were a little fouled runs like it did before.
crisis over
pete wood ·
[Edited on 5-3-2005 by pete wood]
helterskelter400 ·
mine usedta loosen back off again (pull out a little further).
i used the thread "cleaning" studs which worked ok for a while then i swapped motors. dunno where that old motor is now.
Adam_C ·
well...... you picked it.... the bastard pulled out as i took it for a drive and i couldnt attend the wedding but im sure it went off without a hitch and looked great tho.......
:cry me saturday night, so dissapointed
