67 bug as follows:
67 pan with very good pan halves and has irs conversion , also has ball joint beam modified to fit in place of link pin beam ( beam modified not frame head).
rear brakes are super bug and can supply type 3 torsion bars and spring plates. front brakes are disc (stock ) but also have early t3 discs calipers.
motor is stock 1300 but in excellent condition and has a brand new 1500 carb fitted (1300 jets , same venturi size)
Gearbox can be type 3 or bug , or 4 stud swing axle , even wide 5 if you like. C.v's are 2nd hand.
The body is in excellent condition and has zero rust around any window ( windows are out and can get photo's) ,there is a small amount of rust under left hand front guard but its only minimal, heater channels are perfect and have no rust.
Body has a couple of dents but only minor, rear guards are good , fronts have rust down the bottom under h/lights, bonnet has some surface rust , and decklid has a crease but I do have a good spare.
Ialso have about 3 sets of glass and 3 sets of doors, one set of glass comes with near new rubber kit.
I have heaps of parts that could make up a decent bug oh also have a good hoodlining and stock interior.
I'm asking about $700.00 for the lot ,this includes a fair bit of early bug stuff . This is a complete bug + more just in pieces. Call me if anyone wants to know more 0428 427 986 klaus.
Klaus ·
