hey all ive got a set of type 3 wide drums except theyre stuck on the linings and wont turn any advise on getting them off
cheers mattie
Its usually moisture making them stick in 1st place, try a bit of even heat and few taps on the bolt face while turning the axle nut.
tdegens ·
You have to wind in the shoes buy getting a torch light to look in the holes to wind the shoes adjusters in so the shoes dont stick out as far. Sometimes there is a lip on the drum which doesnt allow the drum to be removed without de adjusting the shoes.
have fun
pete wood ·
if you're desparate, WD40, however, you'll need to replace the linings afterwards.
