I believe these had a 1300 standard? am after some sort of performance carb and maybe zorst? anything else i can do with hoiking the motor out? and please no one tell me to just put a bigger motor in....lol
[Edited on 10-3-2005 by Felony]
i hate that!!
Just spent 10 mins typing it out and nothing posts!
Bizarre's link should be read. Very useful info. It all depends on how much you want to spend though.
My advice from experience, if you are going to change the carb get twin carbs. They cost more but icing is a major problem on my single IDF even with heater pipes attached. Basically means I spend more on fuel and the engine is less responsive...
Twin 'Kadron' carbs pop up here every now and then for $3-500. Those and an exhaust will give you a few more herbs... not much, but some
bugeyedbabe ·
felony...mtor were 1300 in the standards, but supers had a 1600..
that is
71 standard bettle = 1300
71 super beetle = 1600
check to see if u have the original motor, if u have, then it should be 1600.
If not, grab the motor number and post here, and we may be able to tell u if it is a 1300 or 1600.
My s72 had it's motor replaced with a 1500 (i think) haven't got into checking it out fully.
that's where u start...work out if it's original or replaced...silly to buy stuff to up the 1600, only to find out someone replaced it with a 1300 4 years ago when the 1600 died (and the 1300 was on their floor at the time)
hope it helps
ColumBUS ·
if ur running a 1300 single port motor, grab a 1600tp. i know you said dont buy a bigger engine, but for the same price as a pair of carvys you can pick up a whole engine, and its only 2 hours max to get them out/in.
THEN you put the webers, extractors, exhaust etc
Felony ·
ok, i havent got engine numbers yet, however looking at where the manifold bolts to the heads, its not just a single lil pipe, its bigger, so i believe that would be a twin port?
