Car weight for All motor class.
https://forums.aussieveedubbers.com/threads/36205/car-weight-for-all-motor-class
Menangler ·
Does any one know the minimum weight for All Motor class in drag racing,
I have read through the entry details for the Compac Attac and it says cars will be weighed but it gives no minimum weight.
HotRodMatt ·
I ahve the compact rules somewhere as a pdf. Will have a look for you.
I think you can still get them from the andra site...
wacked1 ·
here you go off the ANDRA site
ALL MOTOR – DYO - CLASS REGULATIONS
Class Designations: AM preceded by car number.
The All Motor category is designed for full-bodied cars using original floor-pan and no power adders.
Minimum Weights:
FWD 4-cylinder: 1,650 pounds; RWD, VW air-cooled, stock “Type I” case only: 1,750 pounds; RWD or 4WD 4-cylinder/2-rotor: 1,950 pounds. Full tube chassis or back half with non-OEM strut mounts/strut tower permitted in FWD only - add 75 pounds; sequential, clutch-less, V-gate or non-OEM aftermarket transmissions, add 200 pounds. All weights include driver, verified after the run.
Beck ...
you will have to go and get some lead to add the weight
Menangler ·
No, I'm fairly fat these days, should be right.
