Can someone advise/recommend new tyres for a standard Country Buggy? 15x4.5-inch rim?
I would like close to original, not fatties, on std Kombi/Buggy rims...nn[ Edited on 8-7-2005 by VWCOOL ]
country dubber ·
If you want standard they are just the 15 x 4.5 rim with the tyres to suit. I have two rims with good tyres. The rims have been sand blasted and powder coated white.
so what new tyres can I buy for that size? Everything 'off-road' in tyres these days is 16-inch or needs a 6-inch wide rim...
[Edited on 14/3/2005 by VWCOOL]
Chewy ·
You dont need a wide rim
Class 11 racers (stock sedans) use 4.5 rims with 235/75/15 tyres
just tucks in the sidewalls, which isnt a bad thing
and narrow rims wit big tyres just looks sweet.
country dubber ·
I couldnt find an off road tyre to suit the 4.5 inch rim. They dont seem to be available thats why I went for wide rims as there are plenty to choose from for a 6 or 8 inch rim.
Kombi_Rescue ·
the best tyres to suit the std cb rims which is painted black are 15in tyres to suit the small jap 4x4s .these fit very well with only a little bag on the side wall.the overall height suits the cb gearing with no road noise and very good off road manners...you can get good used thru a wrecker.This is the tyre I choose and travelled some 4.5k in germany with them in2003 .by the way the load rating suits all split screens and helps the handling...DSK member
Kombi_Rescue ·
okay thanks - I will take a look! I donlt want any guard clearance problems with wide tyres like I had before...
country dubber ·
I had the same problem with guard clearance on mine until I fitted some coil over shocks at the rear, trimmed the rear guard and fitted rubber flares. Someone had already cut the front guards. I suppose it depends if you want top keep it standard or not. The body on mine was pretty rough and I wanted to use it on sand so I need bigger tyres. It now has 6" rims with 185/70 on the front and 8" rims with 31.10 R15 on the back.
It will stay stock-standard with standard 4.5-inch CB/Kombi rims.
Any ideas on tyres? Need to buy asap... happy to get recommendations from fellow Veedubbers before I begin talking to my tyre bloke...
11CAB ·
A 235/75R15 tyre needs to be on a 7 inch rim so is no good on a 4.5 inch rim.....I doubt you'd find a tyre fitter that would fit it.
That's why I'm NOT interested in a 235, 255, 285 or a 315/25/19 tyre.. I need STOCKO tyres for a 4.5-inch CB rim... :duh
Buggyboy ·
I have 215/75R/15s Goodyear Wranglers on my buggy, are a great size, not too big, not too small, but the rims are the ROH 5.5 I think.
Chewy ·
11CAB wrote:A 235/75R15 tyre needs to be on a 7 inch rim so is no good on a 4.5 inch rim.....I doubt you'd find a tyre fitter that would fit it.
Why does it NEED to be on a 7 inch rim?
what would be a better size?
215/75/15?
Um.... I need a 155 or similar NOT a set of V8 Supercar qualifiers
pod ·
have you thought of a mud and snow type of tread ,had some on my subaru many years ago ,they were made by toyo ask your tyre bloke about that type of tyre:thumb
pod wrote:have you thought of a mud and snow type of tread ,had some on my subaru many years ago ,they were made by toyo ask your tyre bloke about that type of tyre:thumb
yes that's why I'm here asking...:duh
country dubber ·
I went to 4 different tyre places and they cant find the winter tread tyres. I had Bridgestones which had a good tread and the right size but they were 30 years old! The best I could find for the standard 15" rim was a road tyre. The narrow off road tyres were all 16" Thats why I went for a wide rim.
yeah, bugger it, I might have to fit a road-style tyre 🙁
BUMP... I need to choose, buy and fit tyres soon... Must be narrow to fit 15x4.5 inch rimnn[ Edited on 8-7-2005 by VWCOOL ]
vwgolf772000 ·
Antique tyre service have some Cooper winter treads which is just the right size for a CB I will post ph number tonight
helterskelter400 ·
got a pair of these in 7.00 by 15 8ply to go on rear of freinds long term CB project. $110 each incl tube a while ago.
they're a bit tough and heavy. dont know how they'll go but if they are no good they'll just go on some farm implement or buggy or something...
in terms of fitting questionable tyres on rims, dont you just take the tyre and rim in seperate and ask them to do it and if they say they cant, just tell them its for the broccolli harvester or something...
vwgolf772000 wrote:Antique tyre service have some Cooper winter treads which is just the right size for a CB I will post ph number tonight
that would be great! Although I want to do some 'off-road' in my CB (such as Cape York!) I do NOT want to fit wide wheels/tyres or chop the mudguards
MikeM ·
Bridgestone have 14" & 15" offroad tyres in narrow sizes in their 604V pattern. The narrow sizes aren't listed on the website or in their normal catalogues but if you go to a bridgestone tyre centre and tell them you want some narrow 15" desert duelers they should be able to help you out.
There are a couple of Manxs running around in QLD with 14" duelers on the front and there are no 14" tyres listed in the catalogue 🙂
okay _ will ask Bridestone Centre when I pass one
VWCOOL wrote:okay _ will ask Bridestone Centre when I pass one
Head office... no luck!
Desert Bug ·
VWCOOL, Bridgestone Dueller 195/75 or 205/75 All Terrains would be a good choice, Not too wide but still good in the sand at 15psi even down to 10psi if needed without any problems. I ran 215/75 Dueller ATs on the Desert Bug across the Simpson Desert at 15psi for 700ks without any problems.
Cheers, Ian.
Desert Bug wrote:VWCOOL, Bridgestone Dueller 195/75 or 205/75 All Terrains would be a good choice, Not too wide but still good in the sand at 15psi even down to 10psi if needed without any problems. I ran 215/75 Dueller ATs on the Desert Bug across the Simpson Desert at 15psi for 700ks without any problems.
Cheers, Ian.
I agree... but those sizes are too wide/big and will foul on my guards.. I need something around 165 which is why I am having so much difficulty getting tyres to suit my car..
A buggy in the Simpson! SWEET!
vwgolf772000 ·
The tyres I run on my Country Buggy are Cooper sportsmaster glt 165R15 they have an agressive winter type tread and they almost fit under the b onnet.I cannot find the ph. number for antique tyre supplies.
Desert Bug ·
Ask the tyre place if you can have a look in their throw out heap for a 195/75 AT to fit up and try on the front for clearance. Tell them you might be up for a set if the clearance is ok. I think you might be suprised. 165s are smaller than the original fittment tyres which were 6.70x15 same as Split Kombis, 165s are more the same size as 6.40s. A mate has 215/75ATs on 15x6.5 rims on the back of his Country Buggy with standard Arches without any clearance problems and the outside of the tyre is just inside the body line.
Cheers.
vwgolf772000 wrote:The tyres I run on my Country Buggy are Cooper sportsmaster glt 165R15 they have an agressive winter type tread and they almost fit under the b onnet.I cannot find the ph. number for antique tyre supplies.
Golf, Desert Bug
Thanks for the advice on original sizes and what you have - i can get Coopers through my local tyre bloke so I will ask him. I am not too concerned about the spare... but if the Cooper is smaller that the original fitment, it should fit under the front bonnet okay...?nn
EDIT:
I just checked the Cooper website :bounce:bounce:bouncenn[ Edited on 9-7-2005 by VWCOOL ]
Golf, Desert Bug
EDIT:
NO LONGER AVAILABLE..... :cry
I thought I was onto the right tyres there...
Any more suggestions... 15x4.5-inch rims with an off-roadish tread pattern
country dubber ·
You know you just want to put wide tyres on it and cut the guards!
:cry
[ Edited on 18-7-2005 by VWCOOL ]nn[ Edited on 25-7-2005 by VWCOOL ]
:kiss
pod ·
what about olympic air ride 6.70 15 winter tread ,if they still are made , just seen an old one down the local vw place on a wide 5 rim, so took the details😎
Air Rides are from the 60s, so I doubt it... but thanks for the tip. I will check
58camper ·
Antique Tyres in Melbourne(o3 94584433) have Coopers M&S tyres 165/15 in stock. They work a treat on standard CB rims with very little road noise. They are semi agrressive for offroad use. There is only two in stock as at today but more currently on order. Cost is approx $110 a corner. The spare will only fit under front bonnet if tyre is deflated due to rounded sidewalls as against the original winter tread cross ply which was standard 5.60/15 or max 5.90/15. I still have three original cross plys on my CB.
Countrybuggybill
Okay, I will call them and check - my tyre bloke in Sydney rang Cooper and was told that size was NLA...
EDIT: YEEHAH! Will have in stock in 4-6 weeks... ready for SUMMER!!nn[ Edited on 11-8-2005 by VWCOOL ]
GOT 'EM
Finally!
Thanks to Buggy Bill and others
Not quite as knobby as I was expecting and they seem to have thin sidewalls, but I'll see how we go when the black turns to track...
