square holes?
https://forums.aussieveedubbers.com/threads/36340/square-holes
akean1 ·
im trying to fit a towel rail bumper on to super bumper brackets. i need to have square holes for the bumper bolts.
any ideas on where to buy square drill bits?:duh
or how to make square holes in the bumper, they will be re chromed in the future, so im not to fussed about heat marks etc.
HotRodMatt ·
Drill a small hole and get cracking with a small die grinder?
I think you will find they were punched from the factory. Unless you have a substantial hydraulic press and a good square punch the die grinder will be your best bet.
Chewy ·
Or use a drill bit slightly smaller than the width of the square and file the rest out with a square file.
you can buy square hole punches.
Drill hole - put bolt through - do up and it "pulls" a square cutting bit through into a "block" on the other side.
Use to use them when i made switchboards
StenGuns ·
Mate.. I found that number for the chroming..
Modern Plating, Oakleigh Vic, 03 9568 4588 ask for Jimmy or Harry.. Very good work
Rob
akean1 wrote:im trying to fit a towel rail bumper on to super bumper brackets. i need to have square holes for the bumper bolts.
Andy ·
Square file the way to go! Pre-drill first.
Dare I ask what your up to?
akean1 ·
thanks stenguns.
what sort of places would sell those pullthrough punch's?
andy, im going hybrid 50's to 70's😉
Andy ·
You'll have to post some pics when done 🙂
akean1 ·
they will go in members rides under "akean1's on its way"
http://www.aussieveedubbers.com/forum/viewthread.php?tid=34468
akean1 wrote:what sort of places would sell those pullthrough punch's?
not too sure - engineering type places ..... Blackwoods???
here is one link
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemType=PRODUCT&RS=1&itemID=1492&keyword=28056
and here
http://www.classicsandcustoms.com/eastwood/categories/111.asp
Think it is the same one though
Might be too big as well
there is a great tool shop at Granville here
I will see if i can find there buisness card / web site
If anyone sells itthey will
Stanley ·
Or alot of engineering or sheet metal places have large hole punch machines,
They usually have all sorts of dies..where I used to work years ago we had a machine for doing such things...amazing the thickness of sheet the can pinch through.
Obviously this will cost folding stuff.
Special Air Service ·
Break out the file
