Gear box Query
https://forums.aussieveedubbers.com/threads/36356/gear-box-query
Dozza ·
Having trouble finding second gear in my kombi, anyone know any tricks adjudments that can be made??
I dont think the gear box is buggered cause she goes in and changes ok, just needs a bit to much help for my liking.
Any ideas or advice appriciated,maybe a new linkage somewhere???
Dozza
57kombi ·
Just try and see if you can adjust it a bit.
All you do is look under the floor mat, if you have one and you will see that the gearstick is held in position by 2 bolts.
Undo them a bit and move the whole plate back or forward I forget which way, only has to move a couple of mm and then tighten it up again , try that, if worse move it the other way.
Might help. worked for me.
Dave
Old Dubber ·
Dozza,
Check the coupling just in front of the nosecone of the gearbox.
Some more things but depends on what year Kombi/gearbox?
dubcab ·
I had trouble finding 1st and 2nd so I took my bus to volksworld in windsor and they fitted a new coupling ( in front of the gearbox) and now it works a treat. The gearstick almost feels like a NORMAL car, amazing.
jnr356 ·
also check the selector shaft bush at the front
