hey, was wondering if a stock 4.125 t1 box could handle an atmo 12a carby motor.
these were about 112hp when NEW.
so say a used one makes about 100hp.
Anthony
71superbug ·
bump
Che Castro ·
probably. but no box will last if you dump the clutch at 10,000rpm all the time
71superbug ·
wouldnt be dumping the clutch all the time. just wondering as i MIGHT chuck in an atmo 12a for drag wars which is coming up in a month.
anthony
Doug Sweetman ·
Absolutely. SSP box should be fine for that power level - there are plenty of NA VW motors around making more than that running stock SSP boxes.
Like any pobjoy steroid engined car - they are ~ 120hp or so.
71superbug ·
my current box isnt the single side plate box with the 3.88r&p. mine is the 4.125 box with dual plates.
Anthony
Klaus ·
Don't sell yourself short stock 12a's make about 130 hp , that was even in 71.
malcolm ·
the question is the rpm difference between the two motors to gearbox say 5500rpm to 8500rpm
seagull ·
Get the one I have before it goes out the door
Secoh ·
Power doesn't break things, torque does. An atmo 12A doesn't have a lot of torque compared to it's turbo counterparts, and is probably comporable to a reasonably worked 1600-1800cc VW motor, so I'd say it'd be fine as long as you don't abuse it.
Well, that and I have seen some 12A VW's getting around on the single sideplate boxes with apparently no issues.
