Subaru Map Sensors
https://forums.aussieveedubbers.com/threads/36419/subaru-map-sensors
boof2332 ·
Hey All,
Is the stock ej20t map sensor a 2 bar or 3 bar..any one know???My microtech has en external 3 bar and I have a couple of stock ones, and am wondering if they are interchangeable.. I am guessing NO, as Microtech would not have to sell you a new one if they did..
Matt
Brad ·
My understanding is that they are a 2 bar sensor in the stock form. BUT I have never set an EJ20T up so can only go on what I have been told / read.
hotdog008 ·
my understanding is that the ej20t does not have a map sensor it uses an airflow meter for the stock ecu
boof2332 ·
On the bracket that the ignition module is mounted to...there is a sensor that looks like a map sensor...Oh come to think of it, I was once told it was some form of factory boost controller...so maybe it is a type of map sensor.
Matt
Brad ·
mmm better do some more reading then ... I am all confussed now better get back to my EJ22's 😎
hazet ·
No map sensor,the other thing u r refering 2 is the cruize control thing...
hotdog008 ·
that is your boost controller(wastegate actuator)
there should also be a presure sensor there (this changes engine settings for defferent altitudes, i think)
you dissconnect the hose going to the waste gate and turbo housing,but leave
the wiring connected to the boost controller when installing aftermarket electronic boost controll(with factory ecu)
Andy42 ·
Buggy Brad wrote:mmm better do some more reading then ... I am all confussed now better get back to my EJ22's 😎
Yes mmmm you had better do some more reading I wonder will my poor buggy ever live 😉😉 Oh I am looking at some new electronic gadgets for you to install as well :vader
Yeh yeh i know it is not ready for wiring yet :duh
