Fitting a type 4 to an early kombi
https://forums.aussieveedubbers.com/threads/36430/fitting-a-type-4-to-an-early-kombi
242 ·
Has anyone on here fit a type 4 engine to a split window kombi using the stock type 4 fan without converting it to an upright fan?
I have trial fitted a type 4 into my project (including mocking up a rear valance) and it seems as though it will fit with a little engine bay seal custom work.
Engine bay is already hacked about from a previous owner so i thought i may be able to fit my engine with factory fan and tin ware.
Anyone with experience or web links?
kombibob ·
i put one in my early bay, it has the same pull out rear as a split so i think it should be much the same
242 ·
Are you running stock heater boxes on that?
My concern si where the exhaust looks like it will run.
Is the early bay any longer than the split in the engine bay?
kombibob ·
yep stock heater boxes
not sure if bay is longer than split ,ill compare the two tomorrow and get back to you
Andy ·
There are other options. I had an early bay with a type 4 motor, the PO cut the panels from the engine bay of a later kombi and grafted then to the engine bay of his kombi, so the normal type 4 engine bay seal still worked as it does in a later kombi. (hope that makes sense)
Alternatively you can put an upright fan kit on the type 4 motor and avoid those hassles.
I don't know if a splitty engine bay is longer/shorter than an early bay kombi.
:blah
Menangler ·
Engine bay in a Splitty is smaller than an early Bay,
I have seen a stock T4 in a splitty, but it is a tight fit, the fan is very close to the engine lid and the rear bumper needs to be trimmer so the exhaust fits also.
david ·
splitbusaustralia (rob) is doing an unbelievable resto on a twin cab(leo) at the moment you will find all the info on his rebuild in members rides that is one schmik ute and it has a type 4 donk
