wanted split system master cylinder
https://forums.aussieveedubbers.com/threads/36470/wanted-split-system-master-cylinder
Freddie Fender ·
Where do I find a split system MAster cylinder to suit a 62 Beetle?
What else do I need to install this in my car?
warb ·
I was thinking of doing this in my 58, just decided to go with a brand new single circuit one, I have not gone to a dual circuit, but I from what I have seen you just need to plug in the hoses into different holes, you will need to get a brake fluid reservoir with 2 compartments.. i bought mine from a VW shop, about $50 or something.. came with all I needed, bungs etc..
wrecker67 ·
u2u freddie
Dual brake Master cylinders are VERY EXPENSIVE compared to a single system Master Cylinder....
If You find a good used dual master cylinder, Some Brake companies can install a stanless steel sleeve inside the master cylinder... which will never wear out.... well it will last for a very long time IMHO....
the seals on the piston will also last a long time.....
If You have it done, ask them to put new seals in it too...
around $100 to have it done....
Freddie Fender ·
What are the benefits of going dual system over single system?
11CAB ·
SAFETY...........If a hose bursts on the single circuit system you lose ALL brakes......if it happens on a dual circuit system you only lose half the system so you can still stop.
Just use a 68-on system.. dual circuit and quite cheap (but not as cheap as a single circuit one)
what value is your life...
Freddie Fender ·
Thanks for the info.
Chewy ·
I bought a TRW dual circuit MC for about $25US
There is a drawback, the SC ones have a 17mm bore where as the DC ones are 19mm which results in increased peddle effort.
sax ·
I just spent a lovely sunny arvo covered in brake fluid and grease changing
master cylinder, shoes and cylinders.
What I found incredibly bodgy is the main feed from the resevoir to the master cylinder is just a push in rubber thingy instaed of a metal screw in fitting.
Somebody had put a cable tie or two in there to keep it from falling out,
why they designed it like this is beyond me.
sax wrote:I just spent a lovely sunny arvo covered in brake fluid and grease changing
Easy. It works!
Freddie Fender ·
Was going to try and do this work today but have to go out and gig instead. I'll put it off for another day.
