first pic.. here is an exhaust I went to throw on an engine, the other end is on ok, this is where this end lines up, i remember seing a post about this before, what do i need to get that fits?, can i use the same j pipes that are on there now?, if you have what i need, how much? 馃檪
next, I need this plastic cover for the gen, any one got one?
[Edited on 19/3/2005 by warb]
Anthiron 路
it was something like 1300 and 1600 pipes are the same but 1200 pipes are shorter and u probobly have the wront set.
and u dont need the plastic cover neither of my slots have them and my genny is fine and sticks out the arse end of my baja in the rain,
hypo-vw 路
the reason the muffler is not fitting on your engine is because you have purchased the wrong one . It looks like you are trying to fit a 1200 muffler to a 13-15-1600 engine . The 1200 engine is approximately 15mm narrower than the later engines . All you need to do is get the correct muffler and use the same j-pipes you already have . A new german muffler is around $150-00 . If you give me a call on 02 42725644 during work hours I might have a good second hand one and possibly the plastic cover for the generator too . Wayne .:blah:blah:blah
warb 路
cheers wayne, call you monday..
akean1 路
george at classic vee dub has the german ones new on special this month for $120
pod 路
is the motor a 1200as tht pic shows the muffler you have is too wide is that the case or is it not wide enough
warb 路
muff its too wide
pod 路
you have a 1200 motor have an old 1200 muffler here of my beetle just the peashooters are rusty if you want it
pod 路
hey warb did you get a muffler yet, can bring it to nats tomorrow if you want it
