Oil Temp Monitoring for Type3?
https://forums.aussieveedubbers.com/threads/36519/oil-temp-monitoring-for-type3
Gibbo ·
Hey all,
Does anyone use an aftermarket oil temp gauge and sensor on the engine?
IE like a berg dipstick temp sensor?
Is it an easy job to setup?
Who is running what setup?
72FASTY ·
Im running a VDO aftermarket gauge. Sender is tapped into the front of the sump. Havnt had any problems and it seems very accurate. (temp goes up a few degrees if going up a hill etc)
Although sometimes i wish i never new how hot it was running! hahahaha
73t3fastback ·
I have a VDO unit mounted in the additional sump I bought, it had the provision to install the sensor
BiX ·
i have a vdo gauge and sender. the sender is tapped into the back of teh case. the other L bug has its mounted in teh sump plate.
Special Air Service ·
Where do you get the sensors? and does anybody know the part number? Just easier at the parts shop if I can tell them exactly what I want.
