f/s adjustable 68 bus beam
https://forums.aussieveedubbers.com/threads/36543/fs-adjustable-68-bus-beam
t2 ·
hi all
i am selling my fully rebuilt 68 beam with new ball joints , adjusters, bay discs new steering dampener ,rebuilt calipers with new pads , all work done by cbb in penrith.
the beam will bolt straight into your split no probs or mods,included in the price is 2 adaptor plates to retain the wide 5 stud pattern ,i think the going rate for the adaptor plates is around $80 each, these are made from 350 grade mild steel and are very well made thanks to glider 69
darren
47 27 87 00
penrith
asking $1500 , what i paid for it and has not been used more than 20kms since i bought it
[Edited on 19/3/2005 by t2]
[Edited on 20/3/2005 by t2]
BenettonVW ·
Hey Darren, is it still the original width? Narrowing seems to be an option I would be interested in, but I am guessing this isn't narrowed as it sits?
t2 ·
its the standard width, my bus has 6 inch wide rims on the front with 195/50 tyres on it , these coupled with the 10mm thick adaptor plate bring the rim around 10mm in from the outside of the dog leg, and i want the narrowed look myself. i am considering doing the 4 inch chop on this beam but as they are pretty hard to find i am offering it to the masses first. the beam is the same width as a link pin beam out of a split
thanks darren
t2 ·
back to the top
david ·
if you went to this trouble to get this done in your bus what are you going to use instead keen to know if you have a better set up going in it
t2 ·
i guess its going to get chopped
