dipping a floorpan ?
https://forums.aussieveedubbers.com/threads/36564/dipping-a-floorpan
sean68 ·
has anyone had their floorpan dipped ?
is it worth doing and what are the pros and cons of getting this done?
was going to get the pan blasted but there is surface rust in the tunnel which i want to get rid of
am wanting to powdercat the pan as well
a vintage car restorer around the corner from me mentioned dipping the pan
yes or no?
sean
Andy42 ·
Are you just going to get it dipped to strip it or are you talking about galvo dipping it. I have heard bad things about the galvo dipping but I see no probs with dipping it to strip it as they do complete cars and they come out fine. Just use a good sealer strait after to prevent any surface rust coming back.
Pros: it gets everything off
Cons: You then have to dip it again to stop it rusting away from the inside out...
Blast and paint it ($300 from Advanced sandblasting in Brookvale) and load teh inside of the tunnel with fishoil. Then rotate the pan over to smear it over all the inside surfaces
