After trying for ages to adjust the rear suspension on my 72 Choptop Beetle, Im about ready to give up.
I can do every part, except put the leading arm back on the stop plate. As I try to raise the damn arm, the whole car raises, making it impossible to put back on. (I believe it is due to the lack of weight, due to no roof)
I am in the process of raising my rear about 1.5cm, so it is under considerably more tension
i was needing an explanation of this 2, so this is gr8, now that i know how, i just gotta get some adjustable struts 4 up front
Kimbo ·
Couldn't get the "chaining the trolley jack to the car" method to work for me, for some reason. So instead I use a "big" turnbuckle and a length of chain. Bolt one end of the turnbuckle to the top shock mount; loop the chain over the hook on the turnbuckle, and bolt the other end of the chain to the spring plate - tighten the turnbuckle and the spring plate lifts up.
battybat ·
did it this way a couple of weeks ago - used a big chain from the chassis to the front of the trolley jack and just kept jacking till it all lined up. the chassis did actually lift a bit, but only till the slack went out of the chain.
while it works it's a bit heart in mouth, lots of pressure going on there!
the turnbuckle method sounds interesting for next time - or buying the right tool....
Kimbo ·
The turnbuckle method was kind-of fiddly to initially setup, in that you needed to ensure you have just enough threds on the buckle to lift the spring plate and alow you to lever it out of the "groove", and enough thred to unwind the turn buckle so that the spring plate reaches it's lowest point without any load on the chain so you unhitch it - but it worked
penguin ·
1stcarbug,
I have a tool that you can borrow that may be a little easier than the chain and jack system (as good as it looks)
Will speak to you at Klubfest
