Various bits Berg, Porsche, fuel system + heads [Revised +more ]
https://forums.aussieveedubbers.com/threads/36642/various-bits-berg-porsche-fuel-system-heads-revised-more
2443TT ·
Hi Everyone,
I'm cleaning out my garage and found the following things that I'd like to sell.
1. A Malpassi rising rate fuel pressure regulator 1:1 ratio. This regulator can be used for NA use, and also for forced induciton blow thru systems. The diaphram receives a boost signal from the manifold, so that fuel delivery pressure is kept a static (and adjustible) rate above the boost pressure. ie: 3.5lb static + 12lb boost = 15.5lb supply pressure. A must for a propper carb/turbo conversion. The regulator is in used but perfect condition. $70.00 ono
http://www.cairns.net.au/~nqeaho/Forsale/Malpassi.JPG
2. A pair of stock VW rocker gear with gene berg swivel foot adjusters. $70.00 ono
Sorry no pic.... They are still on the heads...
3. VW Twin port 040 heads. Stock and unmodified and un-stressed. No cracks. Perfect condition (just need to be cleaned, which I will have should someone be interested). Exhaust valves have oversized machined in valve stems. All new valves were fitted the last time the heads were on an engine. $120.00 ono
Sorry no pic, but i'll arrange it if your interested.
4. Stock pressure plate. Used and has about 40,000k's on it. Perfect condition. $30.00
Sorry again no pic. Everone knows what a clutch looks like...
5. CB Performance 4 gear dry sump pump (New and unused) $50.00
http://www.cairns.net.au/~nqeaho/Forsale/CB1.JPG
http://www.cairns.net.au/~nqeaho/Forsale/CB2.JPG
6. Bugpack window rubber seal kit. Allows you to make your own window seals. Great for chop tops etc. Brand new and in original packaging... I ordered the wrong item.. $30.00 ono
http://www.cairns.net.au/~nqeaho/Forsale/Bugpackrubber.JPG
7. New 1967 window regulators. Used for about a month on my '66 with my single piece window conversion prior to me upgrading to power windows. $40.00 ono
http://www.cairns.net.au/~nqeaho/Forsale/Regulators.JPG
8. For the ricers, or supercharged/turbo'd vw's that race the ricers ! ... a Tial 50mm blow off valve with 50mm weld on aluminium weld on flange. CNC machined billet design, and it will out flow just about any bov on the market. $200 firm..
http://www.cairns.net.au/~nqeaho/Forsale/Tial.JPG
9. A pair of Porsche 911 964 wheels. Original 17x7 ET55 offsets. These wheels are rare as hens teeth and cost me close on $1200 to land here in Australia. $800 ono/neg.
http://www.cairns.net.au/~nqeaho/Forsale/Wheels1.JPG
http://www.cairns.net.au/~nqeaho/Forsale/Wheels2.JPG
http://www.cairns.net.au/~nqeaho/Forsale/Wheels3.JPG
10. Red only tail light lenses for a '66. Great for a show car, or for a track only race car.
http://www.cairns.net.au/~nqeaho/Forsale/TailLights.JPG
My details...
Located in : Cairns, Queensland
Phone: 0740323529 Home
Phone: 0740527220 Work
[Edited on 23-3-2005 by iswinkels]
matara ·
Ian, I am overseas at present but definately put me down for the Malpassi. I will send you a U2U too.
SKEWtYpe3 ·
interested in swivel foot adjusters
shipped to melbourne, just adjusters?
Darthbug ·
Have sent you a U2U on oil pump
Darth:vader
71superbug ·
would i be wrong to say that these are all parts off of your turbo 1641cc motor?
if so we all know the caliber to which this motor was built and the performance from it. so all great parts guys.
free bump for ya ian
Golde60 ·
ian
can i put my hand up for the 67 window regs
best contact is u2u
2443TT ·
Actually they are mostly off the engine prior to the turbo 1641 motor... This is actually a good thing considering how I drive the 1641 :thumb. It means the parts aren't as stressed.
Also, the 1641 has big valve 044 heads. The ones i'm selling are stockers with stock valves, springs etc.
Thanks for the plug anyway!
Hutcho ·
Ian, If you'll send the wheels and 040 heads to Sydney, Ill take them! Let me know what you want for shipping...
Oh, and if Steve doesnt end up wanting the fuel reg, Ill grab that too, please!
[Edited on 23-3-2005 by Hutcho]
2443TT ·
Just took a few more pics for those that were interested...
The berg swivel foot lifter feet..
http://www.cairns.net.au/~nqeaho/Forsale/Berg.jpg
I also found a few more things...
A SAAS steering wheel with boss. The wheel is pretty shagged but the boss is good. Fits a '66 or earlier. I can seperate the wheel from the boss to make freight cheaper if required. $20...
http://www.cairns.net.au/~nqeaho/Forsale/saas.jpg
http://www.cairns.net.au/~nqeaho/Forsale/saas1.jpg
Last of all, a VDO sump plug temp gauge sender. Replaces the sump plug with a sender unit that hooks up to a standard oil temp gauge to tell you your oil temp. $10.00
http://www.cairns.net.au/~nqeaho/Forsale/VDOSender.jpg
Cheers all,
wiseoldub ·
can i be next in line for the heads and also for the sump plug oil temp unit!
cheers josh
326 booyong road, nashua 2479
northern rivers
cod them
