i got the nuts on my wheels dont up so tight i cant even crack em with all my weight em, any suggestions?
Soak liberally with WD 40
then
Option 1 - breaker bar. If you have a wheel brace slip a long bit of water pipe over one of the cross pieces and heave on that
Option 2 - drive to a local tyre dealer and get them to rattle gun it open for a couple of beers.
Then do it back up with a wheel brace
Dasdubber ·
Dang beat me to it!! I was going to same the same thing. Well done ole' chap.
If car is not drivable, may have to borrow a rattle gun from someone??
~air fooled~ ·
take a whole lot of roids? hahaha.. how bout use a big breaker bar against the ground as leverages and go froward or back? or run down the mechanics and get them to loosen them off a bit with a rattle gun..
~air fooled~ ·
damm it! you all beat me to it! i got yas with the roids though! hahaha
DIY-DUB ·
dammit i wanna rattle gun, will have 2 go the wd and some jumping or bashing or pulling severely, thanks 4 quick replies tho, dont have a bar or nutin, that was the 1st thing i looked 4
Dasdubber ·
Is it drivable/registered?
DIY-DUB ·
registered yes, driveable not really, some wheels off already, and its pouring rain and i dont want 2 have 2 put em on again and dry it off again, can u tell im lazy?
Dasdubber ·
1stcarbug wrote:can u tell im lazy?
Yep :thumb
I can pretty much guarantee the frustration/effort of trying to get the remaining nuts off will be more than that to put the other wheels back on and drive down the servo/tyre shop :P But who knows, you might get lucky - may have to build your forearms up over the next few days "some how" and then try again. :o
DIY-DUB ·
nah i aint sleepin till i get em off, any1 got fast acting roidz i could borro, funny how ive never had an issue with havin em up so tight b4
BiX ·
also try hitting the end of the spanner while standing on it. the shock can sometimes break the nut loose.
DIY-DUB ·
who the hell uses a spanner on wheel nuts? i got a massive wheel brace type thing, works on everything else
Chewy ·
next time dont do them up so tight, if you get a flat in the middle of nowhere then you are shit creek without a paddle.
DIY-DUB ·
note 4 u chewy I didnt do em up so tight, usually i got some1 else who tightens em up more but i dont now
BiX ·
I have a 1/2 inch drive with the correct size socket's for both wheel nuts and the axle nuts. with a 700mm piece of pipe, no wheel nut or axle nut has ever been a problem!! thats why you use a spanner!! (still have a wheel brace the spanner is just for when they are stuck)
DIY-DUB ·
i c, that explains it
toplessbug ·
if you do the bloody things up to tight you WILL distort the disc or drum look at the factory torque its not extension bar tight
Special Air Service ·
mate give the nuts/bolts a belt (or a couple of belts) square on the ends with a decent size hammer this sometimes shocks/jars them enough to help loosen them off.
good luck
DIY-DUB ·
I DIDNT DO EM UP SO DAMN TIGHT, the wd40 was sucessful still required a severe amount of effort tho, but damn i want a rattle gun, makes it so much easier
pyr0 ·
not if u break down on the side of the road it font :duh
DIY-DUB ·
lol true pyro, unless i have airbag suspension ay? mmm seems more useful now
Starbug ·
i find that if i cant get a wheel nut off with heaps of force...
i close my eyes and use heaps of force... closing your eyes works somehow
karmen ·
Special Air Service wrote:mate give the nuts/bolts a belt (or a couple of belts) square on the ends with a decent size hammer this sometimes shocks/jars them enough to help loosen them off.
good luck
a girl like me uses wd
AND a BIG HAMMER squre on....belt bash bang dunn!
~air fooled~ ·
Starbug wrote:i find that if i cant get a wheel nut off with heaps of force...
visualising!! this works big time with all things!
beerdoc ·
Use the hammer on the nuts as per SAS and Karmen suggested
squizy ·
Some people try this method when constipated too.
DIY-DUB ·
i sid problem was solved with wd40 but thanks anyway
