Hi Anthony,
It IS possible to convert a link king pin torsion bar front end to the later Ball Joint torsion bar front end....
I think its nearly a straight swap over.......
depending on the model of the chassis its going on....
there are just 6 bolts holding them to the front of the chassis
plus the shock absorbers [different mounts] axles, hubs & tie rod ends and steering etc....
Tie rod ends may need changing....
Ball joint front suspension arrived in German made Beetles in 1966 model year... [actual date 6th August 1965]
Not sure about Australian made Beetles...
Maybe 1968.... was the first year We had them... that would mean 4 bolt wheels...
Changing Link king Pin front end to McPherson Strut would be a Major untaking and You have to rebuild the front of the car, as the McPherson struts bolt to the Body.....
Not the chassis, as in standard Beetles.... so If You take the chassis off a Super beetle, You cannot drive the chassis around.... You can in a standard Beetle...
Maybe someone has done this changeover....
http://community.webshops.com/user/vw68autobug
[Edited on 23-3-2005 by 68AutoBug]
