No Brake Lights
https://forums.aussieveedubbers.com/threads/3680/no-brake-lights
Merlyn ·
My Brake Lights Went out. Both Bulbs are good, fuses are good, but inspection of master cylinder shows no power through pressure switch when ignition on and peddle down. (M/C only has 1, 2 prong switch.) Have I done enough tests, and if so, do I need to bleed M/C to remove switch and replace.:bounce
micbec ·
I had the same problem. We replaced the brake light switch, no more problem. Didn't need to bleed the brakes though.
:beer
amazer ·
Ditto. Just be quick.
