I'm assembling a new engine (1600 type 1) and about to fit the flywheel. I have measured the endfloat to be 0.65mm. I understand three shims must be used and they come in a number of sizes from 0.24mm - 0.36mm. The assembled end float should be 0.07 - 0.13mm. So for minimum end float I need 0.65 - 0.07 = 0.58mm worth of (3) shims.
Well this aint possible with three shims.....
Any clues or ideas of what is up????? Can I use two shims???
did you get a new thrust bearing cut in???
Sounds like you need to get the case machined and a new thrust bearing put on??
But..... have you fitted the fly wheel???
Aint you suppose to measure end play with the fly wheel on???
Che Castro ·
the flywheel has to be fitted and the gland nut torqued to 300ft/lbs, then you can start measuring the end play, which you either use a dial gauge or a special tool which lets you use feeler gauges.
You should be using 3 shims, it acts as a sort of buffer between the rotation of the flywheel and the thrust surface on the #1 bearing.
did u fit new main bearings as Barry said....
fit the flywheel to the crank without seal or shims then check the total end float...
deluxe hunter ·
Thanks for the replies.
A bit more info. I have used a new empi aluminium case and a 74mm stroke crank. New std bearings - which fitted well.
I did fit the flywheel, although I didn't fully tourque it up - just a firm nip-up. (if it was not tight enough I guess the end float would be increased)
I measured the end float with a dial indicator clamped to the flywhel and measured it on the case/gearbox flange. No seal fitted.
I suggest you go along to a VW shop and have it checked out
