Upgrading my buggy to have thicker and longer torsion bars. I am using the spring plates and torsion bars out of a 58 chassis. One of the torsion bars is quite pitted which makes me wonder if it is any good.
Anyway, if someone has a spare single or set of 24mm, long torsion bars please let me know.
Correct me if I am wrong, but I assuming that type 3 wagon torsion bars will fit as well ?
Use all Type 3 Wagon gear - pressed steel torsion bar thingos (end caps?) instead of cast and thicker torsion bars for higher spring rate than std Beetle. I think they are the 24mm ones
EDIT: eeek! IRS or swing?!
[Edited on 31/3/2005 by VWCOOL]
I have a set of Type 3 available ..... $150.00 if your interested.
there a matching set Left & right
J&SBlue ·
VWCool : it is swing axle - that is why I need to use the old oval spring plates and end caps.
vw54 : thanks for your reply. Is that $150 just for the torsion bars or for everything from a type 3 ? All I can use from a type 3 is the torsion bars.
Thanks Hutcho but a bit big for what I need I think.
Mark.
Thats $150 for the torsion bars.
J&SBlue ·
VW54 - can you do me a favour please and measure the length of one of the torsion bars. I want to know if the type 3 ones are the same length as the Oval ones.
Thanks,
Mark.
yeah no probs will have to do tomorrow now... thats Sat morn
I will post and U2U the size
J&SBlue ·
Cool. Thanks Dave.
amazer ·
grrr were you at the nationals? I had mine there for sale, same price as daves. I think the bars in question are actually 23.5mm.
J&SBlue ·
Sorry Amazer, I wasn't at the Nationals.
J&SBlue
Ive just found n measured the torsion bars...
they are 676 mm from end to end outsides. Let me know if you need them.
J&SBlue ·
Thanks Dave.
Just checked mine again this morning to make sure and they are 626 mm long.
Looks like I have to get oval torsion bars only which is a bummer.
Thanks for your help.
Mark.
well there is a bit of lea way in the torsion housing from memory, so the bar will fit into the tube and allow to float back n forth.
What chassis do you have ??? and what are you doing to it again.
J&SBlue ·
It is a 69 chassis and I am just changing the torsion bars from the standard to the longer stiffer ones from an oval. I have no idea whether the longer bars will fit.
Are you converting it to IRS at the same time or is the pan already set up this way ???
J&SBlue ·
No this is a swing axle setup. That is why I am using oval rear suspension parts.
I suggest that you call Boris at Vintage and advise him the set up you want ... he will no if it will fit up or not.
I also suggest you convert it to IRS while your doing the job.
J&SBlue ·
Thanks Dave.
There is no need to convert to IRS. Swing setup works just fine.
