Gearbox coupling
https://forums.aussieveedubbers.com/threads/37004/gearbox-coupling
lauzboy ·
how hard is it to check/replace the gearbox coupling?
any instructions?
Remove the back seat squab.... unscrew the cover plate on the floor.
Cut the wire and unscrew the grub screws. give it a rattle and remove it.
make sure you align the screw holes and indents on the shaft when assembling and tie wire the screws up when tight
