adapter plate / Subaru ej series > manual box or Type three auto price drop $400.00
https://forums.aussieveedubbers.com/threads/37007/adapter-plate-subaru-ej-series-manual-box-or-type-three-auto-price-drop-400
seagull ·
seagull neil
perth Wait > Awhile
0417997746
item ,adapter plate & drive hub for subaru ej series to type three auto ( or ) manual gear box type three or kombi 1600
New
$400.00 + post
[Edited on 31/3/2005 by seagull]
[Edited on 3/4/2005 by seagull]
[Edited on 11/4/2005 by seagull]
[ Edited on 28-6-2005 by seagull ]
helterskelter400 ·
hey ho seagull. this should work for a 3 rib kombi box? shouldnt it?
i think someone down here was looking.. i will ask around. thanks
seagull ·
yes this would fit spot on
helterskelter400 ·
i think someone is thinking along these lines which a sccoby engine would work well with...
seagull ·
seagull ·
seagull ·
seagull ·
seagull ·
bump
helterskelter400 ·
sorry man, my dude is out. no interest atm.
seagull ·
bump
seagull ·
bump
seagull ·
bump
seagull ·
New kit any one
helterskelter400 ·
just confirming for everyone that this will fit from a ej81 all the way up to the modern turbo motors, it includes everything (incl fastners) to mate the ej motor to a beetle, type 3, kombi 1600, 1800 & 2l box and get drive.
all you'd then have to do is sort external motor stuff.... cooling, carb linkages/efi, exhaust, fuel supply, alt wiring, ect.
seagull ·
its ej20 / 22 , I have not tryed it on a ej81 ?
just think about how a vw blots on to a vw motor ,all the same bolts required , nut on to crank is the same .
the only subaru bolts are for the drive hub ( from auto flex plate ) and four for the motor to bolt to the adapter plate .
I dont think it would fit a 2ltr box ( dont have a box to try it too any way)
Klaus ·
This means a modified flywheel is needed aswell , which bolts to the hub ?
seagull ·
stock VW fly wheel bolts on with Vw bolt
nbturbo ·
Hey Neil,do you have any close up pics of that bracket you have bolted to the auto bellhousing-just near the starter.Are you using it for an engine mount?
seagull ·
Auto mount
O there a spacer behind the plate to make bring it off the starter casting .
I taped the holes out in the auto housing to 10mm
[Edited on 20/4/2005 by seagull]
seagull ·
The auto bracket is the * top mount * and the motor sits on the smaller one , I removed the subaru mounts used the bracket and welded my own pick ups .
the bushes large ones are toyota 75 series and the smaler 40 series .you need to run a sleve through the center so they dont crush up when you tighten the bolt .
My front mout for the auto is the same ( 40 series ) , all workes well .
most off road race cars have this type of set up .
I hope this helps , seagull
nbturbo ·
Very,very neat work you have done there.I assume the Toyota rubber bushes are from the spring shackles.I was going to use Valiant V8 front engine mounts there,but they are a bit bigger than the ones you have used.I don't know if the Toyota ones only on the bellhousing would be enough-I planned on letting the Type 4 hang out like a beetle does.Thanks for the pics-awesome.
seagull ·
O yes there from the spring bushes . I had planed only to run a Vw motor in this , but as The subaru is turn key , service is oly change the oil and clean the air cleaner well what more can I say .
I added the rear mounts due to extra weight of the subaru .
The mounts are neat and may never need to be replaced
Dero ·
You sold this yet???
Andy ·
seagull, are you bolting the type 3 auto into a beetle rear end or using a complete type 3 rear end?
Richard
seagull ·
Dero , I have stock
Richard , I used a stock vw type three rear end from a wagon .I have also used a super bug and cut the horns off .
seagull ·
very early shot
Dero ·
seagull check u2u. I am interested, although conversion is still very much in planning.
Andy ·
Thanks seagull,
I'm actually making a start on my trike (probably take a few years to finalise, so don't hold your breath).
Beetle horns sounds like a good idea, I didn't ralise how much the type 3 relyed on the body for support.
At this stage I'm happy to stick with complete type 3 running gear (motor, tinware, aotu, rear end).
Do you swap in beetle torsion bars for ride comfort?
Richard
seagull ·
No I just left the type three bars in >I put the trike up in the members rides in a few weeks for all to see and ask ? seagull 🙂
seagull ·
Bump
seagull ·
last one left
nbturbo ·
Neil-got any pics ready for us yet?.When you made the front trans mount with the smaller shackle rubbers,what size bolt did you use? I made the sleeve out of 16mm round bar with a 10mm hole.I think maybe a 10mm bolt is not big enough for the torque these things put out.Might try pressing in a 17mm sleeve with a 12mm hole-sleeve should still have enough wall thickness.
seagull ·
I did use a smaller shackel mount ( 40 series toyota ) the sleve I drilled ant taped from each side 12mm .
this way the 25mm long bolts could be removed in side my frame ( was a small area ) If I can find your email address I send you some photos , neil
O bump for my adapter plate 🙂 I can not get over this one not been sold to date .
