Any links to timing belt changing on a 2ltr quad cam ?
https://forums.aussieveedubbers.com/threads/37051/any-links-to-timing-belt-changing-on-a-2ltr-quad-cam
seagull ·
I doing mine , but getting lost on the 4 cams !
subaru.freak ·
EJ20? Drop in to www.ausubaru.com and check out their forum. As far as I'm aware there is no online explanation.
subawee ·
maybe this will help
[Edited on 2/4/2005 by subawee]
seagull ·
hey hey Thank you :beer
ricola ·
The biggest issue is with the belt tensioner. I think it is MY97 and later that have a very sensitive mechanism and must be compressed VERY slowly and then fixed in the short state with a pin through the rod. Subaru dealers have a tool to do this.
Rich
seagull ·
found out the new belt was $195.00 + gst at subaru , coventrys had them for $102.00 + gst
My spark plugs were $19.45 each from coventrys so I replaced them while doing the belt .
seagull ·
O for the belt tensioner I used a allan key
subawee ·
Hey Ricola/seagull,
I changed my belt about a year ago. I took off the tentioner and compressed it in a big vice and then used a stem from a stainless steel pop rivet, worked great. By the way I paid about $75 dollars for the belt. Maybe you could order one from the states, Shipping cost might kill the idea though.
Hope this helps,
Bob
[Edited on 5/4/2005 by subawee]
seagull ·
yes did the same , ( slowly compressed it in a vice ) could not find a pop rivet so used the allan key .
Its to easy to get a belt here , the last one I got from the Usa for my 96 jeep did not fit :cry
[Edited on 6/4/2005 by seagull]
