Driving my bus home from PMGBUS's house in the hills and when I got a couple of k's from home I noticed a funny smell, a bit like sulpher, as though I had a catalytic converter.
What is this smell.
It definatly came from in the engine bay,
Anyone have any ideas.
It also happened the lasrt time I drove it a couple of days ago.
Its got new oil about 250ks ago.at the same time the valves were also done.
Only started to smell the last couple of days, and it seems to happen after a run for an hour.?????
Dave
MikeM ·
Could be the coil. If you run a coil that is meant to have a dropping resistor without a resistor it will over charge. They smell like sulphur when they are getting over charged.
Or it could be your voltage regulator overcharging the battery. Check the charging voltage of your system.
57kombi ·
I am using a new GT coil.New 009, New battery etc,
I will check the battery.
Dave
MikeM ·
57kombi wrote:I am using a new GT coil.
GT Coils come in both types, I think it "GT t" and "GT tr" or something. One requires a resistor and the other one is designed to run without a resitor.
57kombi ·
Would it be the coil as I have done about 1500kms on it and the smell has only started the past couple of days???
Dave
GL1972 ·
Not leaking battery acid?
57kombi ·
Not leaking acid.
Dave
not leaking but bubbling???
Spook spotted this (or similar) smell thing a while ago.
Apparently the batteries in busses have been know too explode and spray hydo chloro every where.
Just do us a fav an have a smell around your battery
Would HATE to hear there was an acid rain :thumb
akean1 ·
i was charging a battery with 3 dry cells, made a really strong smell, killed the battery😠
57kombi ·
Problem solved.
It was the regulator.
It had packed in and was giving over 18volts to the battery while driving.
Fitted a new one $35 and its running great.
