(no subject)
https://forums.aussieveedubbers.com/threads/37340/no-subject
karmen ·
so only needs a helicoil?
have u removed engine?
helicoils can be tapped and redone in an hour or less with engine installed
Secoh ·
use a solid thread repair insert not helicoils on VW spark plugs. But yes, total piece of piss to fix.
Notch65s ·
Yes the engine is not in the car. Selling this engine cause i am upgrading my engine. Will run fine with helicoil
[Edited on 13/4/2005 by Notch65s]
1500S ·
Is the engine an imported 1965 type or OZ production S?
DH
Notch65s ·
i think it is an Oz produced S. not to sure tho. when i drove it, it had just as much power as the 1600tp i have. It didn't run all that well unless on on high octane so it is high compression
1500S ·
The OZ "S" had flat top pistons and was the same as the "N" version. There was only about 1 BHP difference between the 1500S and the 1600 engine. Have a look to see if it has the dome top pistons?
DH
Notch65s ·
Bump
