split kombi fuel tank
https://forums.aussieveedubbers.com/threads/37369/split-kombi-fuel-tank
tdegens ·
Any ideas as how to change the split tank for a bay efi tank or put two larger fuel plugs into th xisting splitty tank. I want to persevere ith fuel injection into the splitty so the tank needs to be altered.
Kombi_Rescue ·
just fitted a bay efi tank to my splitty ..goes straight in and the fuel out let is in the same location as the split tank. do your self a favour and cut and shut the split filler tube and weld on a L bug end peice so as to eliminate that fuel smell in fast lh handers..of course have a proffessional do any welding when it comes to fuel tanks...ps you need to lengthen the fuel tank straps in the splitty to fit a bay tank or you can use old saftey belts as these work well as fuel tank straps cheers dsk member
