Running in a new engine
https://forums.aussieveedubbers.com/threads/37435/running-in-a-new-engine
LOWBUG ·
This will be interesting, how many different ideas there are on running a type 1 engine stock or heavily modified engine.
Go for it guys
Flying VW ·
I just rebuilt my Motor and I kept it below 3,000 Revs for about the first 200 miles or so, now I'm driving it like I normally would.
But I've only done short trips like 45 minutes or so.
I think Short trips with various Speeds are the best for running in.
HotRodMatt ·
Never ever lug it.
Lots of gear breaking.
Fresh is best! Run it like you normally would.
Varying loads and speeds without going over 3000 for the first couple of hundred is good. No lugging low revs up a hill either.
Motors are tight when new and run a little hotter an that is why they should not be over revved until they loosen just that little bit.
tassupervee ·
Just drive it like you normally would but avoiding lugging and very high revving of the engine for about 800 K's
sax ·
If you want a fast engine, run it in the same way you would drive it.
Dont be too gentle on it, redline is good especially after the first 40-50 miles.
Use cheap oil and change it every year or so, really helps.
If you run it in too gently, you will never make good power and will have a sluggish engine. Give it heaps and see the difference.
A whole lot of bullshit is written about engine run in proceedures,
you have just read some more of it!
:blah
Peter Leonard ·
ahh but which post was it in ?
as others have said.... No lugging about...
Rev it....
Driving normal with a full load is good for an engine...
makes it work....
But VW used to say....
Drive it out of the showroom and just keep going....
No need to run in a VW engine.... Just drive it....
Back in the early 50s... Most Cars had to do all sorts of things to run in their car... as No high Revs - 3000 was high back then!!
then they had to de coke the head etc....every so often..
NOT so with the Beetle....
Push the accelerator down once to bring in the auto choke and then turn the key... then drive away....
No warming the engine beforehand as with other cars back then....
VW s were a mile in front of other cars back in the 50s & 60s.
LOWBUG ·
This all sounds great, the non labouring I agree with. But what about modifide engines, or stock engines with newer components made from better metals, and then theres newer oils, do you use running in oils or not, sythetic normal?
Has anyone done these comparisons?
tassupervee ·
Seems some like to run in on plain mineral "running in" oils and put in their favorite brews later on.
I dun use any special running in oil. Just a mineral multigrade till the first change and whatever synthetic after that.
Im my race engine, I run them on synthetic from the start and dont really bother much with "running in". perhaps about 15 to 20 laps at slightly reduced revs. I just drive the arse off it after that!
Modified, stock, I treat them in the same way. Just drive them around like normal 'cept just keep the revs up, but not sky high.
Work the bastards! Playin around at low load/revs "can" result in glazed bores and bad ring seating.
L8tr
E
Dasdubber ·
Courtesy of John at Aircooled.net (bit of a read but worth it):
Prepare to Run!
Install the engine into the vehicle or onto your engine stand, and get prepared to crank it over. REMOVE THE SPARK PLUGS AND OIL PRESSURE SWITCH. If you have a T-4, you can just remove the spin on oil filter. Next, crank the engine over until oil squirts out the oil pressure switch hole (or the oil filter bracket on the T-4). Re-install the oil pressure switch (or oil filter, which you have filled with oil), and connect the oil pressure switch wire. Crank until the light goes out then continue cranking for another 10 seconds or so. The oil system of the engine is now ready.
Set the ignition timing on the engine (you do know how to do this without running the engine, right?) to the proper setting for the distributor you are using, and install the spark plugs and plug wires. Install the pushrods if you have not done this yet, and adjust the valves to .008" (better loose until things settle in). Hydraulic lifter engines can adjust them to 1 ½ turns tighter than "zero" clearance. Make sure you have fuel pressure, and fire it up!
Running the Engine!
This next step is VERY IMPORTANT! Immediately bring the rpm's up to 2500 or higher. I vary the rpm's between 2500 and 4000, and do this for 15 minutes while keeping your eyes glued to the oil light! A second person back at the engine looking for oil or fuel leaks is a REALLY good idea too, since you don't want a fire or Valdez in your driveway! Most oil leaks will occur very soon after startup, if at all. Now, this is a nerve-racking experience to have the engine (it sure seems loud!) at these rpm levels when it's NEW, but if everything is OK, it's going to be fine. Remember that this engine is not even under a load, so it's not a big deal.
After the 15 minutes has elapsed, shut down the engine, and change the oil and adjust the valves. When you fire the engine up this time, you can let the engine idle, and make the needed carburetor adjustments. Drive the car easy, and change the oil and adjust the valves again after 100 miles or so.
Now that the "bearing break in" is done, you want to REALLY heat the engine up by driving it hard! This loads the rings and will break the pistons, cylinders, and rings in together. I have found that engines that are missing the flaps or thermostat assembly have a tough time seating the rings in, and the only cure for this (my experience) is to get the engine HOT (some of these engines "never" break in). Find a hill and drive full throttle up the thing a few times, in a gear that loads the engine down a bit. The loading and extra heat burns the glaze off the cylinders and allows everything to seat together well. I do not feel a longer "break in" period is needed (some say 10,000 miles) other than getting the rings seated, and this can be done in 500 miles.
Repeat the oil change/valve adjustment at 500 miles, and then resume your normal maintenance schedule (which hopefully does not mean oil changes every 15K miles, and/or valve adjustments once a cylinder or two goes dead at idle).
Now for some explanation!
The reason for the varying of engine rpm at initial start up is that the VW flat four engine does NOT adequately oil the camshaft lobes and lifter heads at rpms below 2500. The oil for the cam-lobes comes from oil sprayed off the connecting rods! If the engine is run below 2500 rpm for too long, the cam and lifters do NOT break in together properly (since they don't get enough oil) They get enough oil for running, but not break-in. In addition, you also run the risk (the higher valve spring pressures you run, the higher the risk) of one or more of the cam lobes getting scored and even going flat. Some engine builders (myself included) will run the engine on one set of valve springs for break in, and change to the competition springs (really heavy) after the cam and lifters are broken in. The cam and lifters must work together under a moderate load (valve springs), to allow the metal to work harden before extreme loads are placed on them. This oiling quirk is also the reason for cranking the engine for oil pressure with no valve spring pressure on the camshaft (no pushrods, remember?). With really heavy valve springs, just this cranking alone can damage the cam if racing spring pressure is present!
Maintenance Schedule
Schedule oil changes every 1000 miles (no filter), and every 3000-5000 if a filter is present. The oil strainer (stock VW) does NOT count as a filter, and in fact I remove it on engines that turn over 6000 RPMs! I have seen more engine failures caused by this strainer than I care to count (even on stock engines), so I leave it out and change oil religiously. One more thing! The new strainers that are available are of a much more corse "mesh" than the originals, so any "filtration" is minimal. The addition of a magnetic drain-plug is a good idea! I adjust valves to .006" every 3K miles (it does not take long, nor is it difficult) on old engines, and every 500 miles (until adjustments settle down) on newer engines. Keep a record of valve clearances at every valve adjustment; when a valve gets "abnormally tight" compared to the rest of them for 2-3 valve adjustments, it's a warning sign that the vavle is stretching and is ready to fail! Valve job time ( and replace exhaust valves)!
tassupervee ·
It works for him.
Untermensch ·
Just get in and drive it. Gently for a while then change oil check tappets and
go for it.
Andy42 ·
yep no need to do anything special just drive it as you would normally.
fullnoise ·
I broke the cam in on my engine as described above at 7:30 pm on Easter Monday. I only got abused by one neighbour.
I've been told not to let the engine idle during the break-in period.
CYA CT
CT
you should know - drive it to Bathurst....... HARD!
Easy! Live near the twisty Old Pacific Highway like I do! 😉
malcolm ·
as helbus and others said but drop oil after start to check for metal
winerot ·
i clocked mine the day after it was put in (i know silly silly)
the speedo is miles had the dail hit the 90mls plus.
that was three mths ago now & today went 700kl's,
never run so good.
frank2112 ·
The method we used to use for our Holdens is to run at fast idle (2000 rpm) for about 15 mins and then take it out on the road for a good flog for about half an hour. thats how I ran in the last six I built. After that it revved its head off and always felt really strong. For a VW I think the factory method would work. It depends if they run the engine on the bench before it goes into the car or not.
I have read where idling is bad for Your engine.....
Driving with a few passengers is good for Your engine....
So, all these low kilometer japanese engines have sometimes idled for most of their life.....
so a 40,000km engine has in reality done an extra 80,000kms of idling in Tokyo traffic....
Peter Leonard ·
bollocks.
Personally I don't mind giving them a hard time. My supercharged 202 in my EH was in a burnout comp only 500 k's after rebuild. Those bores won't be glazed up I can tell you.
try this:
www.mototuneusa.com
Dasdubber ·
This could be of some relevance - a fairly "controversial" break in procedure as claimed by the author - some quite good info here:
http://www.mototuneusa.com/break_in_secrets.htm
sounds like an info-mercial which pi$$es you off quite a bit. I didn't see anything about cam break in....but nonetheless, just something else to consider
[Edited on 13-4-2005 by Dasdubber]
Dasdubber ·
VWCOOL wrote:try this:
www.mototuneusa.com
Crap, sorry VWCOOL, I only just read the link you put above - beat me to it :o
No worries dude.. . I have a freshly-rebuilt 1916 sitting in my garage and I'm gonna run it in using this bloke's methods, I think...
Peter Leonard ·
of course there ARE fast-lapping rings.....
tassupervee ·
Im sorry but I cannot see ANY logic in this little gem.
Dasdubber wrote:If the engine is run below 2500 rpm for too long, the cam and lifters do NOT break in together properly (since they don't get enough oil) They get enough oil for running, but not break-in.
They get enough oil for running but not for break in......
Give ME a break!
L8tr
E
Agreed. Dasdubber... sorry, but what you hae written makes no sense...
tassupervee ·
hehehehe nah dasdubber didnt write it, he just quoted it from Aircooled.net.
Im compeletely buggered as to how this snoozer works out that there is sufficient oil to run it but not sufficinet oil to "break it in"
What a crock of shit!
l8tr
E
toplessbug ·
ever seen a flat cam? i have seen plenty -mostly from auto,s idled around town all their lives . what this dude is trying to emphasise i think is that above 25 there is enough oil being tossed about to wash away the heat and debris generated during the running in process . if people are left to their own devices they would start a fresh engine then happily let it sit at idle while they admire their handiwork while the innards grind away without sufficent oil flow over the non pressure fed parts
hellbugged ·
i'm with das, crank the engine for oil pressure by hand without plugsand rockers, then oil push rods, springs and rockers and fire it up-above 2500 for 5 minutes. splashing oil from crank provides lube for the cam to work harden. think about the cam lube- how many times would an engine have turn over before cam lube is wiped off the follower and cam!adjust valves and fire again! like if you had a remote filter- do you just screw a new one on when replacing it or fill it patiently with oil before hand, same goes with the empty oil lines to a remote filter, cranking for pressure before firing means instant pressure at start up before all the heat associated with a running combustion engine.
[Edited on 15/4/2005 by dumone]
tassupervee ·
tassupervee wrote:Im compeletely buggered as to how this snoozer works out that there is sufficient oil to run it but not sufficient oil to "break it in"
E
Ok ladies, read it again and have a think about it K?
The comment is close to preposterous!!
Oh yes, i have seen the results of an insufficiently lubed cam, such as many Holden V8's where the lobe was damaged.
However, to state that there is enough oil to actually run it but not break it in is a load of bollocks. either there is enough oil, or there isnt.
Why do you think you use "cam lube" (moly-disulphide grease) on a new cam and lifters?
Moly grease on the cam faces with protect it for a suprising amount of running time untill the oil comes along and washes it off. In that event, there must be enough oil.
In addition, every engine i build I use moly grease on all the bearings as well as opposed to using plain oil.
l8tr
E
