FS - Zero Miles 1776 Engine
https://forums.aussieveedubbers.com/threads/37459/fs-zero-miles-1776-engine
Grey 57 ·
For sale 1 x re-build 1776 motor.
T3 (Converted to T1) motor. Eng No RR16204. Just been rebuilt by VW trained mechanic.
Has,
- New 1776 P & C's
- Re-ground standard crank (20thou)
- Re-built Twin Port Heads (New valves)
All assembled to long motor stage.
Also fitted with a 200mm x 6volt Flywheel so it will drop straight onto a 6volt gear box , but have the added benefit of the larger 200mm clutch.
Need to clear this out as I want to put the money into my T34 Ghia and it has a 911 motor in it so this one will not be used.
$1,500. (No offers)
I can put you in touch with the builder no problems.
Call Dean 0412 500 588.
Located in Melb. Can bring to the Jamboree next weekend if required.
Heres some pics. Nothing flash as the out side detailing not done.
Grey 57 ·
Another pic
Grey 57 ·
😎😀:thumb
stephenianjames ·
U2U sent Dean,
kroozzn63 ·
would 1500 tinware fit and it would go in my 69 baja 12volt what needs to
be done with the volt difference ?
ruckus ·
i have a feeling this has been sold?
