Anybody got one they want to part with. It is different to the beetle gearshift housing.
tom degens
coffs harbour
2450
66584264
plus and original gear shift rod would be great.
[Edited on 12/4/2005 by tdegens]
do you require it to fit a tunnel gearbox into an Oval or do you need it for a Splitty???
If your fitting a tunnel box into an Oval your better off welding in the proper front gearbox mount... much easier and will align better.
tdegens ·
fitting into a splitty. The splitty had a trushift 5 speed and I want it to go back to a 4 speed.
JOE751 ·
5 speed? this then also had a rear axle mod? reduction gears removed?
tdegens ·
the trushift 5 speed keeps the original front mount and rear axle setup and reduction hubs or an irs can be put in. The trushift gearbox gearcarrier housing is made by trushift and is a bit longer for the extra gear. the gearshift housing which holds the transmission selector is also changed and the position of the transmission selector is higher so the gearshift rod is higher so a universal joint setup is used. Thus the gearshift rod has been changed so I am going to try to get an original.
Lots of luck trying to find one..... there hard as hell to locate.
tdegens ·
is the split case gearshift housing the same as the tunnel case gearshift housing
No the Beetle and Kombi nose cone shifter housing are different.
most people want them so as to mount a tunnel beetle box into an Oval chassis.
JOE751 ·
wow I was asking round a couple of years ago at mechs about getting a 5th gear in the splity, but they all said I'd have the change the axle...
bugger...how much does one of these setups cost and are all the ratios the same exept for the 5th gear?
tdegens ·
the fifth gear ratio is lower .
cant remember by how much, will have another look when I take the box out again which is most likely.
tdegens ·
anyone with a splitty gear box nose cone and selector shaft out there that they want to part with
tdegens ·
or can i fabricate a front gearbox mount so it is lower to line up with the tranmission selector shaft
If you can find someone to weld magnesium... thats what there made of
